Old 09-21-2006, 09:56 AM
Nick@lockitup's Avatar
Nick@lockitup Nick@lockitup is offline
Originally Posted by Nick@lockitup
autozone carries all the parts.
SBK1 for the inner spindle kit.
set 45 for the outer bearing set
471271 -inner seal
lm104949-inner bearing
jlm104910-inner race
Thats for any big bearing d44 waggy/chevy
all these are timken part #s btw
Old 09-23-2006, 12:04 AM
HorribleHarry's Avatar
HorribleHarry HorribleHarry is offline
Location: Encino, San Fernando valley, Los Angeles, California, USA., Earth, Orion arm, Milky Way galaxy
So let me get this straight (since my truck is broken & 50 miles away...)
is there a seal on the outer side of the front hub? is this part of the chrome cap? my waggy was spraying bearing grease all over the place onto the outside of the wheels & tires... never got around to popping them off & taking a look.
Thanks,
Harry
86 GW, 360-V8, NP229, Tow Package(3.73's), D44/AMC23, aux. 25 gal. fuel tank, 2.5" lift, 31"BFG AT's, dual Flowmaster exhaust w twin cats, factory brush guard, PIGNOSE transplant!, rust, shiny chrome valve covers! ...and no more woodgrain!
89 Range Rover classic hunter (with factory standard leaky head gaskets!!!)
87 Vanagon SYNCRO 4X4
Old 09-23-2006, 06:22 AM
Crazy_Jeepman's Avatar
Sloppy Shifter
Thanks,
Harry
No there is no seal in or behind the Chrome cap. If you have grease spraying out of it, then I would be concerned that a wheel bearing is failing and heating up the grease enough to turn it to liquid and that is how it is managing to get passed the cap, or the cap is a poor fit and is allowing the grease to get out. Although there really should not be nothing more than a light coating of grease behind the cap and in the drive flange area, the grease should be moderately heavy within the area wheel bearing cavity only.
Old 09-23-2006, 10:20 AM
Thank you Crazy_Jeepman,
My caps are beat, but I seem to remember the hubs being pretty warm.
I will rebuild them when I put my manual hubs on.
Harry
Old 12-13-2006, 10:13 AM
mxg342 mxg342 is offline
Please forgive me for my ignorance but are any of these part numbers for the inner axle seal? I've been starting my search for new ones but measurements and specifications are not matching up. The old seals were 2.5" to the best of my measuring ability. I can only find 2.25 and 2.625 seals on advance auto parts website. Can anyone help me out here?
Old 12-13-2006, 02:13 PM
Gambler68's Avatar
Rabble Rouser
yeah inner seals are listed there. 2.625 is alot closer to 2.5 than 2.25 is. (talking about 125 hundreth of an inch difference vs 250 hundreths).
post up what you have for a rig, in your sig, this helps people give you exact answers more often than not.
taking your old seal in and bribing the parts monkey with candy helps Occasionally you get a helpful one that will match parts for you.
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 12-14-2006, 07:18 AM
Thanks for the info. I'm working on a D44 front from a 79 waggy. It is going in my CJ. I'm planning the 5 on 5.5 conversion with Ford stuff, ARB, 4.56 gearing, and high steer. I'll probably switch to hydro assist steering next year. $$$ is to tight right now for it.
The bad thing is we have put the project on the back burner due to my roomates jeep getting totaled. We are rebuilding a 91 chevy truck as fast as we can now to get him back in a vehicle.
Old 12-14-2006, 10:38 AM
Gambler68's Avatar
Rabble Rouser
wow, that looks so bad, the dog wouldn't even pee on it!
bad hit, sure it was a bummer.
Old 12-29-2006, 04:35 PM
Gambler68's Avatar
Rabble Rouser
471271 -inner seal
ok..dumb question... I need to buy TWO of each to do the whole diff, right?
Napa: BRGBK1 : 15.99
Azone: SET45 15.99
Azone: 471271 4.99
Azone: lm104949 16.99
Azone: jlm104910 4.99
all that x2 = 117.90 before tax sound right?
Old 12-30-2006, 12:11 PM
Gambler68's Avatar
Rabble Rouser
okay got that one answered
I guess a pair of Brute Force joints wouldnt hurt either, thats prolly another 50 bux.
Old 12-30-2006, 12:15 PM
Sloppy Shifter
Yup 2 of everything................Brute Force? who makes them? I generally just get a Spicer Joint.
Old 12-30-2006, 12:19 PM
Me too. Not much chance you will mess one up unless you lock the front axel.
Old 12-30-2006, 12:26 PM
Gambler68's Avatar
Rabble Rouser
its a Azone sealed bearing lifetime warranty..prolly 10 bux more than the spicer.
Old 12-30-2006, 12:44 PM
Sloppy Shifter
Yea I just checked them out its actually a Neapco brand, same as what is available at Advance auto. I have stayed away from them........I feel Spicer is the premium OEM replacement.
Old 12-30-2006, 12:48 PM
Krista has a set of those Brute Force joints on Phoebe's front axel for over 3 years Ryan. They have held up fine. I don't know how the heck you can have a zirt fitting on one of these axel joints to begin with. The ones I just did on Wally came with fittings, 2 types. Neither will fit with axel in place. So, I pumped them with grease before they went in and stuck the cap fitting in.
Here is what I got at NAPA last month...
371 Ujoint - price $30.68, net $22.99 x2 $45.98
And there are 3 seals for the Hub/Axel. One is actually a dust seal of sorts that goes on the base of the stub shaft. Then there is one next to the inner cage bearing (you should replace these bearings too - maybe that is what the SBK1 kit is, bearing and seal?), then the outer seal on the inside of the hub. I couldn't tell you now which one is which, but I got mine at NAPA:
711818 - price $5.20, net $4.69 x2 $9.38
24898 - price $5.50, net $4.99 x2 $9.98
22311 - price $9.45, net $8.49 x2 $16.98
