6 and V8 have the same bolt pattern, but 6 and v8 flex plates are balanced differently so you need the 6 cyl flex plate. Also will have to lengthen front driveshaft and shorten rear shaft, and make minor mods to shift linkage since trans moves back six inches or so. Crossmember has two sets of bolt holes to chose from, so it just needs to be repositioned. Seems like some changes in emergency brake cables too, and oh yeah motor mount towers, easy if you have a donor rig, PITA otherwise
FSJ's
'89 Grand Wagoneer
'81 J20
Trucks:
'48 4WD truck
'54 4WD truck 226
Flatties:
'51 CJ3A
'46 CJ2A
'47 CJ2A
'48 CJ2A
FSJ's previously owned:
'77 J10 short bed
'67 Wagoneer (RIP)
'70 Wagoneer (RIP)
'78 J10
'73 Wagoneer
2 each \'64 J300
2 each \'70something Cherokees
