Old 04-20-2009, 08:10 AM
mcjeep80's Avatar
mcjeep80 mcjeep80 is offline
opinions.. build a d44 or find a d60
i cant seem to find a ford d60 front for my rig. i can get a hp ford d44 from a '79 f-250. someone cut the stub shaft out with a torch. so it would need a total rebuild. if i put chromo's and beefy u-joints, do you guys think it will hold up to some 42s? the HP will also help with me font d-shaft angle and the 44 is free and just down the road.
'80 WT.cherokee-tbi454/4l80/241c
welded rockwells/ PSC full hydro /3"body lift
front soa on 3" springs/inboarded 63s rear
42x15x16.5 TSLs on 8 bolt H-1s
'77 Honcho, 454/th400/div.205
3" body lift/3" of aal
35x12.5x16.5 thorn turds
DD/Tow rig, 2005 5.9 Cummins 3500 CC/LB
Old 04-20-2009, 08:25 AM
jeeping1974's Avatar
I highly doubt that a HP44 would last with 42s no matter how well you build it. Heck even 38s would be questionable.
Why not use a chevy or dodge D60 front end? There has to be some of those near you.
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
Old 04-20-2009, 08:35 AM
jtr's Avatar
jtr jtr is offline
If a d44 is locked, it will not live long with 35s.
Jeep is gone ~~ Ranger cab truck in the works
393W/C6/203-205, HP60, 14B, 12 bolt H1s, 40" Pitbull Rockers, full hydro, 4 link rear
Build = http://www.pirate4x4.com/forum/showthread.php?t=973973
Old 04-20-2009, 08:48 AM
Chevelleguy's Avatar
Because then he would have to change to a passenger drop transfer case.
Get a later model Dana 60 and move your springs to the outside of the frame.
Old 04-20-2009, 09:44 AM
Desert Rat Desert Rat is offline
35s is about as big as I'd go, and that's with upgraded shafts and Ujoints.
I've busted stock ones with 33s and a 4 banger.
With 42s, even a 60 becomes a bit fragile if you're locked and regularly romping the truck.
www.nissan4wheelers.com - we're the guys using up all the spare driver drop waggy axles!
Old 04-20-2009, 02:53 PM
Michael's Avatar
Michael Michael is offline
Hey do not waist your time or $$$$ remember what happened to mine in Cruces last year? That was my first run on the front 44 I knew it would go but not that fast. That was with the 36's. I could not find a 60 here either. Look on Pirate. I found mine there....had to pay freight but it will be worth it in the long run.
1994 YJ
Amc 360
TF727
Stak 3 speed
44" Pitbull Rockers on Trailworthy H1's
Rockwells
76' Wagoneer
401....new project
Tow Rig Daily Driver// 2007 6.7 CTD Dually
Old 04-20-2009, 03:09 PM
fullsizejohn's Avatar
fullsizejohn fullsizejohn is offline
Find a 60.
When i did my SOA i went ahead and put flat tops and high steer arms(as well as ball joints,new axles joints and brakes) on my d44s. With 37" tires, i ran that for a season but with stock gearing it was sick anything out of low range. I knew i needed gearing but by then i knew i didnt want to put more money in the d44s.
Moral of the story...If i had found a 60 to begin with i would be about $800 ahead plus my labor cuz now those d44s are behind the shop collecting dust.
Find a 60 !!!
'77 cj-5,
'78 j-10,(not running)
'79 J-10 360ci,t400,D300, SOA-D60w/ARB, 14B w/Detroit,4:56s, 37" TRXUS
'06 Ford F250 super duty crew cab
Old 04-20-2009, 03:49 PM
Dmntxn77's Avatar
Dmntxn77 Dmntxn77 is offline
Hey watch this...
D60....
Old 04-20-2009, 06:07 PM
rockjeep44's Avatar
The Advisor
I wouldn't wipe my *** with a Dana 44
Buggy Buildup
Originally Posted by welchct
Old 04-20-2009, 06:17 PM
you wouldn't wipe your three asteriks with a D44? lol.
Old 04-20-2009, 06:39 PM
Well, I would, but not for Virgil's application.
I watched you wheel Virgil, you want/like to wheel hard.
That's not really me or my usage, but for you, tossing $$ at a D44 will be sort of pointless.
Cash in hand (I know, that's my issue also) you are not going to make a front D44 ever be a D60.
Get some spare shafts, carry some spare parts and save the $$ for later.
Old 04-20-2009, 06:47 PM
JERSEY JOE's Avatar
front 60
For an FSJ I would go right to a 60. You will also need to think about converting to spring over. Mid 80's Chevy one tons had the driver's side drop. I just recently finished a narrowed J-20 front D44 for my CJ 7. It's got Reid knuckles, Dutchman axles, lockers and 4.10's. Will be using it with 37 Krawlers. I know even in a light CJ it is going to be on borrowed time, but who knows... My issue is that I want to retain the spring under and the 60 never came that way.
1987 J-20 401 90% COMPLETED.
1970 AMX CURRENT PROJECT
Old 04-20-2009, 06:57 PM
incommando
Posts: n/a
I think you mean "still had pass. side drop." When GM went to driver's drop, they went to IFS, IIRC.
Old 04-20-2009, 07:17 PM
JERSEY JOE's Avatar
GM axle
You are quite correct sir, my mistake
Old 04-20-2009, 07:35 PM
blt2krl's Avatar
blt2krl blt2krl is offline
Dana 60, "set it and forget it RONCO."
Paul Hartman
79 waggoneer
AMC360/TH-400/203/205
www.cbioffroadfab.com
WWW.PLANET4X4.NET
Old 04-20-2009, 08:35 PM
Desert Beast's Avatar
Desert Beast Desert Beast is offline
360 AMC
why go with a baby dana 60?
you know you want to go with rocks.
Old 04-20-2009, 09:04 PM
TheJeeper's Avatar
TheJeeper TheJeeper is offline
I'm not suggesting a 44. But John Cappa (editor at JP magazine) is running 38's in his '73 J-10 with stock axles, (rear 44, 19 spline 2 piece axles, front 44, closed knuckle, 19 spline shafts). I know he's on "borrowed time" as well, but he's making 'um last. It all depends on how you drive it, what engine you have, and how you use the skinny pedal.
'65 J200: 230ci., T90A-1, built with T90J input shaft, Spicer 18, 2.47:1, D44s: 4.27s. 31x11.50x15 vintage Star M/Ts
Regarding a manual valve-bodied auto... "To me that's like trying to play a fiddle with a sawzall."
Nothing in written by me in ANY post can be used without my written consent.
~Eli's Jeep Supply~
Old 04-21-2009, 07:42 AM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
you can make anything last long if you have the right gearing and you are gentle with the skinny pedal. But, 85% of folks that wheel (remember, 95% of statistics are made up) aren't like that
I'd go with a 60 and run 35 spline if you are running 42's.
BJ's Off-Road
ryan@bjsoffroad.com
Old 04-22-2009, 12:55 PM
Heimeken's Avatar
Heimeken Heimeken is offline
I've broken a couple of u-joints on the 44. Which lead to breaking the shafts. Could not find a Ford that I was willing to pay for. So I am going with the Chevy 60. I found a Dodge 208 that will replace my 208 and drops to the right. Will have to see how the clocking works out and will have to modify the exhaust. Will post up when I get to it...
401, NV4500, 3/4 ton gear
'79 Cherokee "The Sandgorgon"
One Tons, SOA,T18 on 40's
78 J10 "Imoteb"
J20 running gear and axles
Old 04-22-2009, 12:59 PM
rockjeep44's Avatar
The Advisor
I believe the Dodge 208 has a slip yoke output. Just something to keep in mind.
Buggy Buildup
