  #941
Old 11-25-2019, 05:30 PM
mwood65's Avatar
mwood65 mwood65 is offline
Damn!
Yours looks better in the before pics than mine probably will in the "done" pics....
You have a good solid base for your project at least.
Old 11-29-2019, 11:26 PM
Full Size Jeeper's Avatar
Was able to get all my door catches cleaned, painted and installed. Also chased all the threads.
Old 11-29-2019, 11:27 PM
Old 11-29-2019, 11:29 PM
All four doors are on the Wagoneer!!!
Old 11-29-2019, 11:36 PM
Now for the bad news. The paint we painted the front fenders, hood and tailgate was mixed wrong, and is slightly darker than the rest of the jeep. I have enough of the right paint to fix it, and will at some point.
Old 11-29-2019, 11:41 PM
Cleaned up and started installing door internals. Drivers side window regulator and door latch is adjusted.
Old 11-29-2019, 11:43 PM
Door handle installed with new gaskets.
Old 11-29-2019, 11:44 PM
Very happy to be putting parts back on the Wagon!!!
Old 11-29-2019, 11:50 PM
My son installed the weather striping on the front passenger door. Looks really good, but it is very tight, hope over time it seats a little and makes for easier closing of the doors.
Old 11-30-2019, 05:53 AM
rws31's Avatar
rws31 rws31 is offline
2 of our doors were the same way. Very hard to close after the door gaskets. Tried adjusting them which helped a little but they are still harder than the other 2.
Bummer about the paint color.
1988 Ramcharger
2003 Durango 4x4
1982 CJ7 4 banger
2008 MB E320 Bluetec
Old 11-30-2019, 10:46 PM
... but I'am no painter. ...
MORE LIES!!!!!
All your posts after 11/25, I only see a minus; no pictures. Did you change photo hosting pages?
Old 12-07-2019, 07:55 PM
Was able to work on getting the small windows on the rear doors built. Kaiserjeeps build thread is where I went to figure this out. Thanks Al for the help locating rivets and tools, I know you saved me weeks of leg work hunting down parts.
Old 12-07-2019, 07:56 PM
tool
Old 12-07-2019, 07:58 PM
Tool in action.
Old 12-07-2019, 07:59 PM
built divider bar
Old 12-07-2019, 08:02 PM
Old 12-07-2019, 09:45 PM
Kaiserjeeps's Avatar
Hey no sweat Darin. I went back and edited the part numbers into my build thread. So it looks like the oval head rivets worked just great. I used the big flat head rivets and had to turn the heads down in a small lathe. A regular time consuming pain. So good news on the rivets working without custom work. And is it not just cool to have a quality tool like that rivet press. You have to assume that a tool for airplane brake shoes is probably going to be well made and not a compromise import pile. It is well made and works like it should. I put a super small drop of oil on the head of the die. It seemed to help coax the brass in place.
And yes, bummer on the paint color. I had that happen with the tailgate cover panel. It was darker than the rest of the rig. I did not expect to need more paint and would have mixed both cans if I had known.
You wagoneer is looking so darn good! My wife just leaned over my shoulder and said, hey another wagoneer and had a good look. We are enjoying your build. Don't finish it too fast...
Am I done yet?
Holy Moly, I am done.....
1969 1414X Wag,
1970 and 71 project J trucks
1970 Wagoneer Not Sadie
1983 FJ60 wagon
CJ-5's and a 7
Old 12-07-2019, 10:42 PM
Thanks Al! Wanted to let you know, I tried to install them like you did with the bottom gasket out. I could not make it work, it was to tight with the new gaskets. (I think you reused the old gaskets on Saide) I put it back together and pushed the lower gasket past the inner and outer door skins. Then once the top of the glass is past the upper door channel, you can push the lower gasket back up where it belongs. Pretty much like the TSM says to do. You talk about a handful trying to handle a wet and soapy piece of glass. Thanks again, Darin.
Old 12-12-2019, 05:37 AM
rws31's Avatar
Ditto. I probably wouldn't have replaced our felts yet if I hadn't seen Kaiserjeeps job in his thread.
For you not being a painter, that thing is looking awesome. But isn't it a lot funner putting on parts and not get all greasy.
1988 Ramcharger
2003 Durango 4x4
1982 CJ7 4 banger
Old 12-16-2019, 09:07 PM
SteelyEyedJeepMan's Avatar
SteelyEyedJeepMan SteelyEyedJeepMan is offline
Cam woes
The cam I have is a comp cam that has been nitride treated. Also have the solid lifters with the small oiling hole in the bottom for extra insurance. This cam has 523 lift, so it is a little bigger than the other cam I melted.
Did you (or your machinist) ever come to any conclusion as to why two lobes failed?
You used proper assembly lube, you used high Zinc oil, you ran it on an engine stand at the proper RPM. What could you have done different?
I'm asking because I'm about to put together a 360 with new cam/lifters.
Did you think about going with a roller cam, or are there just as many issues with roller lifters?
1978 Cherokee, 4-door
FrankenJeep (Turbo Wagoneer) build thread Ghinmi Street & Performance 230 10-04-2015 09:11 PM
How tall for a daily driver / mild off road Wagoneer lorenmjones General FSJ Discussion 18 09-11-2014 05:57 PM
Build thread - 3x Grand Wagoneer 89/90/91 sportsidedan General FSJ Discussion 22 09-03-2013 12:11 PM
