Old 05-31-2020, 01:12 PM
xavier296 xavier296 is offline
2 voltmeters show low
89 Wag, and the dash volt meter consistently shows low (~10 when not running, ~12.5 when running). A multimeter shows 14.25 at idle between the battery terminals, and 14.0 at the B sensor wire going in to the cluster.
I bought a used gauge cluster, thinking my gauge was bad, and the new one shows only slightly higher than above. Even when using a power probe with 12.7 volts going to the connections on the back of both gauges, both still show about 10 volts. Did I get unlucky and buy another cluster with a bad volt meter?
Thoughts?
Old 05-31-2020, 06:59 PM
Yes.
Old 06-02-2020, 10:03 PM
I have ran into high resistance at the plugs on the firewall causing gauges to read low. Might be worth a look before condemning the gauge.
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
2010 DWE show jeeping1974 North East 0 05-20-2010 04:30 AM
7th Annual Wolverine 4-Wheelers 4x4 Show May 31st Livonia, MI mtxbigtruckin Events 7 06-06-2008 08:28 AM
6th Annual Spring 4x4 Show Low Country Jeep Club nicsfsj Events 0 04-07-2008 09:17 PM
Wolverine 4x4 Show Results and Pics now online. mtxbigtruckin Events 8 05-17-2007 01:22 PM
