  #41
Old 05-20-2019, 03:50 PM
SC/397's Avatar
SC/397 SC/397 is offline
This is what I did to your timing cover to help with the so-called hydro relief idea. https://www.pirate4x4.com/forum/jeep...ro-relief.html
I just use a very small round file and file a relief in to where the center of the gears would meet.
IMG_1646 by Rick Jones, on Flickr
IMG_1647 by Rick Jones, on Flickr
Old 05-28-2019, 11:10 PM
Ok, It's in!!! AND IT WORKS!!! WOOOOOO HOOOOOO!!!! Update on my build thread. About 40PSI on mechanical gauge (hot idle) and 32 on my dash gauge with 20/50. I was not able to try it with 10/40 because I was out of oil plug gaskets. I picked some up tonight but I had already showered so I was not able to test it.
The block off was seated well.
Old 05-29-2019, 11:13 AM
chubbinius's Avatar
Great to hear! Must feel great to see those numbers where you expected them to be and to see it on both mech/dash gauges too!
1970 1414X Wagoneer "The Pig"
-Dauntless 350 V8
-D27 front/D44 rear
2006 XK (65th Ann Edition)-DD
Old 05-29-2019, 01:27 PM
When I first started my engine I was paranoid about wiping a cam lobe because I was firing on an untested EFI. Then every time after i was paranoid about wiping bearings from low oil pressure. When I saw good oil pressure, I FINALLY got the feel the feeling of triumph!
As I was installing this, I kept playing playing over the terrible scenario:
What if I still have low OP? Do I pull the intake and check for a hold in the galley? Bad lifter maybe? is a cam bearing missing? What if my oil pickup is bottomed out on my oil pan? So happy!
Old 06-03-2019, 09:59 PM
Great news!!!!!
1984 GW
360
Comp 260H
Magnum Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
ideas of a build thoughts desired. thomastenn Off-Road FSJ Tech 8 10-25-2010 03:57 AM
401 Piston thoughts? aallison General FSJ Tech 2 03-03-2010 08:46 AM
Your thoughts would be appreciated twojeeps General FSJ Discussion 4 10-21-2009 08:40 PM
258 rebuild thoughts Zorm General FSJ Discussion 11 04-02-2008 09:25 PM
transfer case thoughts lasinvegas Off-Road FSJ Tech 9 12-23-2007 05:35 PM
