Old 03-10-2007, 01:59 PM
duracell's Avatar
duracell duracell is offline
need to lower a back window
i was wanting to remove something from a junk yard wagoneer and since i'm one of those "don't want to break it cause someone will need it guys". how do you lower the back window? would removing the motor be the best way? and is it like removeing the window motor's same screw/bolt holes?
Old 03-10-2007, 05:13 PM
jpcoutts's Avatar
jpcoutts jpcoutts is offline
Go to the tech section of the archives and look for the articles there. There are more than one and they are very good.
Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
Old 03-10-2007, 05:17 PM
Mikel's Avatar
Mikel Mikel is offline
In my Cherokee I used to remove the clips from the motor arm's, slide the arms out of the guiding rods and the window would drop.
1969 M715 6x6
1963 J300 Swivel frame
Old 03-10-2007, 08:02 PM
Big rock (wear gloves/safety glasses), I just tossed 6 wag/chero rear windows this past week.
No one will need that one (there are many more out there).
Sorry, but it's true.
Old 03-10-2007, 10:33 PM
duracell's Avatar
i soooooooooooooooo wanted to do that but BRENDA said karma and relented i almost did it 3 different time's and just walked away
Old 03-10-2007, 10:54 PM
johnwaynejeep2
Posts: n/a
You can try using a motorcycle battery and some jumpers to activate the motor. If the motor is fried then go with Mikel's suggestion, just watch your fingers cause these windows are heavier then you might think.
Good deal on not breaking the window. As tempting as it is and as common as these windows can be, luck will see that it's the only window in town and Murphy will make sure you break your window within a week after breaking the junkyard one.
Old 03-11-2007, 12:01 AM
chrisnsarah's Avatar
Mikel had it right. A pair of sidecutters to cut the retainer clips and slide the arms out. The hard part is reaching up in there.
If it's a u-pull-it type of yard and the Waggie is either picked clean or has been there awhile, I wouldn't feel too guilty about breaking the glass either. Many go to the crusher with the rear glass in place. I've seen many broken by people who either need to get the tailgate open or need to scrounge a regulator or latch piece.
'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
Old 03-11-2007, 08:58 AM
Gilgar Gilgar is offline
I just lowered two windows on junkyard Wagoneers. I did it using a small 7/16 wrench. You can just fit in on the mounting bolts for the electric motor. Once it was out, I still had to work to get the windows down because the side tracks were so old and chewed up. After doing the first one, the second one (which had the window I wanted) came apart in less than 10 minutes.
Stewart
'89 GW, Skyjacker 4" lift w/nitros, 33" BFG MT's, and ARB air lockers.
Old 03-12-2007, 09:28 AM
duracell's Avatar
thanks for the idea's. i'll try a couple out before i go with the big round key
Old 03-17-2007, 11:49 PM
Soggy Boots's Avatar
Soggy Boots Soggy Boots is offline
Window lowering
I just did this last weekend I used my 14.4 volt makita drill battery after removing all of the screws in the door I cut a section of harness bared the wires and touched the battery it worked great after the window I wanted to remove the seats (front) took the same plug so I could move the seat up and forward and to the rear for easy bolt access now I have the piece of wire in the junk yard box as a tool and you can also tell if the parts are worth messing with.
Old 03-20-2007, 09:28 AM
duracell's Avatar
that is a good idea
