Old 03-08-2007, 11:51 PM
J10Mike's Avatar
J10Mike J10Mike is offline
Delightfully Incompetent
Spray on glue?
I have some rattling aluminum door panels. I found some 1/16 inch padding on a roll that will work great.
The question is...Is there a spray on glue that I can use that isn't hazardous to my health or the health of my passengers?
www.j10mike.com
Former - 1982 J10 Sportside, 360, TFI, 727/208, J20 axles, D44HD/Detroit TruTrac, D60/Detroit Locker, D60 disk brake conversion, 4.10s, 5 inch Superlift, 35x12.5x16.5 BFGs on AR767 Wheels. Procomp Super Seats. MileMarker 9000 on Cliffhanger front bumper. Dozer II rear bumper. Rhino Grill conversion. NP208 floor shifter conversion.
Old 03-08-2007, 11:53 PM
I got the Willys....
3M makes a good interior spray on adheasive. IIRC they make a regular and a HD. Go with the stronger of the two. I used it when I made my door panels, and it worked well.
1971 Gladiator
Old 03-08-2007, 11:55 PM
J10Mike's Avatar
Tom,
Where can I find it?...Any common local stores?
www.j10mike.com
Old 03-08-2007, 11:57 PM
Yeah, just about anyone should have it. I got mine from Walmart. It was about $5 a can.
1971 Gladiator
Old 03-09-2007, 12:03 AM
J10Mike's Avatar
Thanks Brother
www.j10mike.com
Old 03-09-2007, 12:16 AM
adamsclarke adamsclarke is offline
Super 77 is the best stuff to use. Spray both surfaces evenly...let it tack up for a minute or two and then stick em together,.....they aren't going anywhere with that application.
Old 03-09-2007, 12:23 AM
elskeptico's Avatar
elskeptico elskeptico is offline
The real HD stuff made by 3M is "Super Trim Adhesive 08090". There's also another one they sell as trim adhesive that will probably work. The 08090 I've only been able to find at Autozone, but the lighter-duty one is more widely available.
1979 Cherokee Chief S, 360, TFI, Part-time conversion, rust
If you go lookin' for rust, you'll find it.
Old 03-09-2007, 06:25 AM
Agreed - but it's a contact adhesive, so place your parts carefully. Available in the small can at Home Depot last time I looked. Any arts&crafts store will have it too, likely in the big can.
Old 03-09-2007, 07:19 AM
OBX-AUTOMOTIVE's Avatar
OBX-AUTOMOTIVE OBX-AUTOMOTIVE is offline
GRUMPY
I'VE USED SOME KIND OF GLUE STUFF FROM ACE HADWARE,IN A CAN THAT YOU BRUSH ON,IF I REMEMBER IT WORKED GOOD....3M HAS TWO KINDS OF SPRAY TRIM GLUE THAT WORK REAL GOOD!...I JUST FIGERED I LET YOU KNOW ABOUT THAT OTHER ACE STUFF.....
Old 03-09-2007, 07:32 AM
Bob Davis '80 Chero
Posts: n/a
Super 77 is what I used on my J10 (#1) headliner and the heat of summer caused it to release (stop holding). I used canned contact cement for laminate counter tops next and that holds in all weather.
Old 03-09-2007, 01:08 PM
waggy401's Avatar
waggy401 waggy401 is offline
The HD 3M stuff is great for high heat applications. It is THE recommended stuff for installing hood insulation. I have used the lighter-duty stuff on door panels and it works great, but the Super Trim Adhesive is even better.
89 Grand Wagoneer, 360, 727, 229, D44s, 2.5" Rancho lift, 31x10.5 mud tires, Howell TBI on an Edelbrock intake, MSD TFI upgrade, Engle cam, Edelbrock shorty headers, Single 2.5" exhaust with 40-series Flowmaster, Milodon high-flow water pump, BJs Offroad aluminum cross-flow radiator.
Current Jeep Status: She's alive!!
Old 03-09-2007, 02:13 PM
J10Mike's Avatar
Thanks Guys,
I went to Walmart during lunch and found the regular 3M adhesive. I didn't see the HD stuff. But, it should work just fine. Afterall, the door panels will be secured with screws anyway. I just wanted to lessen the various rattles when driving.
While I was there, I picked up a pair of Sony 6x9 speakers to put in the doors. I figured if I'm going to pull the door panels, now is as good a time as any to install speakers so I can get rid of the junk speakers behind the seats.
That's my weekend project.
www.j10mike.com
Old 03-09-2007, 03:06 PM
tjsean0308's Avatar
tjsean0308 tjsean0308 is offline
I love the 3M stuff I use the 90 strength all the time for stair treads carpeting speaker enclousures all sorts of stuff. highly recommend takeing the nozzle off an soakin it in some type of solvent the glue is crazy stong I had a problem with the nozzles clogging beteween uses.
Old 03-10-2007, 08:21 AM
Gilgar Gilgar is offline
You can find the 3M stuff at Home Depot. I found some stuff that I like from this place:
http://www.raamaudio.com/cgi-bin/index.cgi?p=pr
Stewart
'89 GW, Skyjacker 4" lift w/nitros, 33" BFG MT's, and ARB air lockers.
Old 03-10-2007, 08:44 AM
GRUMPY
....YEP/ER ....THAT WHAT I WAS TALKING ABOUT, CONTACT CEMENT FOR COUNTER TOPS FROM ACE!...
