Old 09-02-2018, 08:27 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
Transmission type in 1988 wagoneer
i know it is fairly easy to identify the diff transmissions used in the wagoneers
but it is even easier to ask people in the know,...so:
did all 1988 wagoneers have the same automatic transmission type ?
i think over the years the used 727's and GM transmissions
if someone knows the answer i would appreciate the info.
mine is a 1988 GW, what trans did it come with ?
thanx
dave in NC
Old 09-02-2018, 10:34 AM
joe joe is online now
AMC bolt pattern chryco 727.
Old 09-04-2018, 01:45 PM
gpcl16 gpcl16 is offline
By '88 they had phased out the 6 cylinder so it should be a V8 with 727. Not sure if it's relevant to you, but I believe that the regular versions (with 2.73 gears) had a torque converter lock-up clutch, while factory tow package equipped rigs (3.31 gears) had no torque converter lock-up, so there were in fact, two slightly different transmission options even in the final years.
1988 Jeep Grand Wagoneer
4" BDS Suspension Lift
Tru-Trac Rear
Howell GM TBI with Custom Tune
Old 09-06-2018, 08:44 AM
SOLSAKS's Avatar
10-4 thanx !
Old 09-06-2018, 11:44 AM
EasTXJEEPER EasTXJEEPER is offline
While we are on the subject of FSJ Automatic Trannys. What is standard automatic for a 83 Cherokee Laredo with a 360? Were there any options available back then ? Previous owner may have ordered my Laredo with a Towing Package.
Old 09-06-2018, 03:21 PM
Same trans AMC cased 727. Every AT behind a 360 was the 727 from 80 till the end.
1988 grand wagoneer power window motor SOLSAKS General FSJ Tech 2 01-22-2018 10:15 AM
1988 wagoneer radio surround trim SOLSAKS General FSJ Tech 4 10-02-2017 12:26 PM
82 Wagoneer transmission problem. Eddie General FSJ Tech 27 05-05-2008 08:13 PM
Kick down TH400 Bill Lawton General FSJ Tech 10 09-28-2007 10:07 PM
