Old 08-16-2008, 12:06 AM
codyy codyy is offline
Rear axle question
Don't know where to put this but here goes. I have a question about rear axles. I've already searched a bit on this site, checked the tech library too a bit. Not too much. Is there a write-up somewhere that can tell me what different stock rear axles were used on these FSJs? The axle in question comes from an '82 Cherokee, 6 cyl, manual trans. If I could, I'd like to find out the gearing too. Thanks.
Old 08-16-2008, 12:17 AM
Forgot to mention that the axle is a 6-lug if it helps.
Old 08-16-2008, 12:59 AM
J10Mike's Avatar
J10Mike J10Mike is offline
Delightfully Incompetent
On an 82, its an AMC20 (23) rear axle. Gearing will be 2.73 or optional 3.31 (tow package).
Is it a 4 speed manual or 5 speed manual?
If 4 speed, it's the T-176. If a 5 speed manual, it's a T-5.
Take a wire brush and a wrag to the front D44. There will be a tin tag on the left sie of the diff that reads what the gears are.
Hope this helps.
www.j10mike.com
Old 08-16-2008, 10:34 AM
I have another question. Is this Cherokee possibly a wide-track? I don't know much about the difference between narrow and wide tracks.
Old 08-16-2008, 10:41 AM
Kali's Avatar
Kali Kali is offline
http://www.bjsoffroad.com/cartgenie/....asp#Widetrack
1982 J-10 Pioneer
Check out my YouTube Channel !!
Check out my Instagram !!
2018 Grand Cherokee Upland
"The J-series Jeep pickups are simultaneously the ugliest and the most beautiful trucks ever made."
Old 08-16-2008, 12:16 PM
847JeffL's Avatar
847JeffL 847JeffL is offline
Hate to hijack but what were the axle ratios available on 83 J-10's? Is there a stamp or a tag on the axle tube to notate which it has?
1983 J-10 360, 727, NP208, longbed, TFI upgrade, K&N filter, Flowmaster delta 50, Edelbrock Intake(3731) and Carb(1400), Summit 8600 cam, 4" Hellcreek Suspension, 3.73 gears, Treadwright 33x12.50r15 D/Mud-S, Minty's Model 29 15x10 wheels.
Old 08-16-2008, 01:30 PM
bushwood44's Avatar
bushwood44 bushwood44 is offline
If its got the wide flairs its a wide track
88 Grand Wagoneer
99 Camaro z28
73 Honda st 90
79 F250
