Old 05-08-2006, 08:10 AM
ctjeepman
Posts: n/a
Sealed Beam Headlight Converisons?
Has anyone tried replacing their old headlights with something newer and can give of better light? I was thinking of something like this
http://store.racinglab.com/raysquartyps.html
But am unsure if a stock electrical system could handle it. Any real-life experiences out there?
Old 05-08-2006, 08:28 AM
i have the hella setup in mine.
they're nice.
Old 05-08-2006, 08:50 AM
Spectre's Avatar
Spectre Spectre is offline
Yup. I'm running Sylvania Silverstars in mine, and my Jag has Autopal H4s. No problems either way.
"Battlewagon": 1986 Jeep Grand Wagoneer (w/ Tow Pack) - Urban Assault Wagon under construction - TFI, TBI, CS144, Aftermarket Sanden, Explorer Power Seats, 4" Lift, 16" AHI wheels and much much more; click here for a full list of modifications and gear, links to writeups/posts and more info.
Daily Driver: Modified 1987 Jaguar XJ6 Vanden Plas.
Old 05-08-2006, 10:01 AM
JeepinPete's Avatar
JeepinPete JeepinPete is offline
I will second the improvement Hellas make...
Pete
Isuzu 6BD1, NV4500, NP241
Old 05-08-2006, 10:06 AM
i need to upgrade my wiring to the headlights next,i'm about 1.5 volts shy at the light socket.that's a lot!
Old 05-08-2006, 10:27 AM
Grimjaw's Avatar
Grimjaw Grimjaw is offline
Try this write up at http://www.cfsjc.com/forums/showthread.php?t=30
Ivan the Terrible
1979 J10 360/400/bw1339
Old 05-08-2006, 10:45 AM
David Allen Racing's Avatar
David Allen Racing David Allen Racing is offline
I'm running a H4 set up with 120w high/ 90w lows in my off road truck. I also added a painless wiring kit# 30815 headlight harness.
http://www.painlesswiring.com/
78 Cherokee Chief "The Beast" 401 - 35" boggers - chopped top
http://www.davidallenracing.com/cherokee.htm
67 M715 http://www.davidallenracing.com/M715.htm
67 M35 http://www.davidallenracing.com/M35A2.htm
Old 05-08-2006, 12:11 PM
CustomWag's Avatar
CustomWag CustomWag is offline
I'vd also got the Sylvania Silverstars and they are a vast improvement over the regular halogens, just plug & play, no wiring upgrades so it's cheap & simple.
Rick
84 Custom GW
360/727/208/d44f/AMC20r/3:31
Manual windows/locks/seats
Old 05-08-2006, 12:36 PM
ctjeepman
Posts: n/a
Originally Posted by Grimjaw
I would love to but I'm not a cfsjc member-any chance on reposting it here?
Old 05-08-2006, 02:45 PM
Grimjaw's Avatar
I am asking for permission to repost the entire thread here.
Ivan the Terrible
Old 05-08-2006, 03:38 PM
ctjeepman
Posts: n/a
thank you sir
Old 05-08-2006, 05:54 PM
Shaggin' Wagon's Avatar
Shaggin' Wagon Shaggin' Wagon is offline
SilverStars. No brainer.
"I am just a simple caveman. Your strange ways frighten and confuse me."
Keith Brunson
91 Grand Wagoneer
05 Z71 Suburban
05 GMC Crew Cab
Various WMDs
Old 05-09-2006, 05:37 PM
Grimjaw's Avatar
Reposted with permission from CFSJC.com ....
Green Giant02-20-2006 01:43 PM
Low-buck H4 Headlight Conversion Now W/Pics
I submitted this to Zack Heisey for the upcoming FSJ magazine, but given the controversy surrounding the new ownership and the change of focus I will share this here, as it may never see print and I worked too hard on it to let it die.
This ranks right up with the TFI conversion in my book. It is something I should have done along time ago.
I'll add pics soon.
Low–Buck H-4 Headlight Conversion or WOW, I should have done this a long time ago.
Parts List:
Materials
1 Pair Autopal HL102P43T Head Lamp (w/H-4 bulbs) $38.94 Autopal Lights (Ebay Store)
2 ea. Optronics A-715 30Amp Horn & Auxiliary Light Relay $3.97 Advance auto Parts
2ea. Motormite 85713 Primary Wire Green 12gauge 12ft. $ 1.98 Advance Auto Parts
2ea. Littelfuse FHAC2BP Heavy Duty Fuseholder w/Cover $4.99 Advance Auto Parts
2ea. 20amp ATO fuses
3ea #10 Pan Head Sheetmetal Screws
Assorted crimp type terminals
Heat shrink tubing
Total spent: $ 60.82
Time required: 2.5 hours
Tired of not being able to see the road when driving at night, or in rainy weather? Tired seeing shadows in front of you because the vehicle behind you has brighter lights than yours? Here is a low-cost way to upgrade your old sealed beam headlights. Pardon the pun, but the difference is like night & day.
Where do I find the conversion kit?
I started by searching for H-4 conversion lights that would fit the headlight buckets in my 1978 Cherokee Chief. I found plenty of expensive conversion kits, but being frugal (cheap, tight, whatever) I searched until I found a set I could afford on my almost non-existent FSJ budget.
I found what I was looking for on Ebay at a store called Autopal Lights. He has just about any type of vehicle light you would need at reasonable prices. I got the round 7” lights, but he has the rectangular ones for you late model aficionados as well. The Autopal light kit consists of a glass lens and housing with a rubber dust cover and an H-4 bulb. I ordered the 55/60W bulbs in order to be street legal, but different wattage combinations are available up to 120W. I would strongly recommend re-wiring with a heavier gauge wire for the higher wattages. Everything else I found either on the shelf at Advance Auto Parts or I had in my garage supplies.
Steps to see the light.
First disconnect the negative cable from your battery. Then remove the 3 screws securing the trim ring or door as they are referred to in the Technical Service Manual. (I also removed the entire grille, although the conversion can be done with the grille in place.) Next loosen the three screws that hold the retaining ring (not the aiming screws), and rotate and remove the retainer and unplug the old sealed beam. Sealed BeamRemove the four screws that hold the bucket in place and set the bucket aside. Repeat for the other side.
At this point it is recommended that you inspect the entire headlight circuit and replace wiring and connectors as needed. (Mine were in excellent shape for their age because the original owner kept the Cherokee in a carport all of its life.)
The conversion units come unassembled, so you must remove the plastic plug and install the bulb in the housing by loosening the two wire clips, discard the plug. Do not touch the glass part of the bulb with your bare fingers as the oil in your fingerprints may cause premature failure of the bulb. Grasp the bulb by its metal base, line up the tabs with the slots in the housing and secure with the clips. Push the wire harness through the back of the bucket and install the dust cover over the plug. This is tricky because the plug is t-shaped and the hole in the cover is round. You will have to stretch the rubber around the plug. Plug the bulb into the harness push the dust cover up snug to the housing and install into the bucket while lining up the tabs on the housing with the slots on the bucket. Make sure the bulb is upright in the bucket as they are “aimed” for a right hand drive vehicle. Place retaining ring onto the housing, line up the slots with the screws on the bucket and rotate into place. Tighten the retaining ring screws. Install the bucket into place. Repeat for the other side. Replace grille, trim rings, etc.New Lights
Now on to the fun part: wiring.
Locate the wire loom running along the right fender that contains the headlight wiring. Loosen the loom retainers using a flat blade screwdriver and fish the wires out of the loom. Consult the proper wiring schematic of your vehicle for the color code of the two headlight wires. (Mine were gray and gray with a tracer.) HarnessOr you could trace the wires back from the right headlight. Cut the two wires close to where they pass under the windshield washer reservoir and pull the wires back towards the firewall until you have about a foot of each wire showing. Splice
Mount your relays in a convenient spot. (I mounted mine on top of the fender between the reservoir and the ignition module to ensure that they were high and dry.) Drill 2 holes the proper size and spacing to mount the relays and an additional hole for a ground.
Splice enough 10 or 12ga wire to the wires coming from the headlights, marking the wire connected to the tracer wire with a piece of tape.Marked WireCrimp-on female blade connectors to the wires you just added and to the wires coming from the firewall connector. Make two short ground wires with female spade connectors on one end and a ring terminal on the other. Screw them to the fender for a ground. Mount the relays to the holes you drilled and connect all the wires to the proper terminals. The relays will come with a schematic. Relays
Locate the “hot” side of your starter solenoid, or some other connection point that is “hot” constantly, such as the positive battery terminal. Run one or two 10ga wires from this location, around the firewall to the relays, leaving enough on each end for your connections. (I used two wires, but you could run one and split it at the relays.) Install female connectors and attach to the relays. Splice fuse holder(s) on the other end of the wire(s) coming from the relays. Use crimp on ring terminals on the other end of the fuse holders and attach to the power source you previously selected. Install 20amp fuses into the holders and reconnect your negative cable. Fuse holdersTest.
Can You See The Light?
Ivan the Terrible
Old 05-09-2006, 05:40 PM
Grimjaw's Avatar
now for the rest of the repost....
woodclad02-20-2006 03:53 PM
Lazy man's conversion for those with $$$
Green Giant,
Great article. Are H4s the same as those blue HID headlights which I cuss when I see them coming at me at night, or are they easier on the eyes of oncoming drivers? Just curious.
Found this on the IFSJA site, for those who have the bucks to take the easy way out: jayrodoh@yahoo.com in Lakewood, OH has no-cut conversion harness kits costing $70 for systems up to 100 watts and $80 for those H4 systems which will run over 100 watts. I have not used one of these conversion kits myself.
Green Giant02-20-2006 04:16 PMJeff,
The name's Todd, sorry should have put that in my sig.
H-4 bulbs are just regular halogens. They are avialable in different wattages up to 120w and different colors, so yes you could get the "blue" if you wanted them.
Mine actually have an unusual pattern that is completely flat on top, so I was able to aim them easily. I had the chance to really see them "shine" (pardon the pun) this past weekend. I drove out to our farm to get the wiper motor off my parts rig, got invited to stay for a wing, beer, & bull session around the firepit that my Bro-in-law was hosting. Hhhmmm free wings & beer......
Anyway, the test of my new lights was driving back home on a cloudy moonless night on dark backroads. All I can say is the difference is indescribable. This will be one the first mods I do on my 69 when I start on it later this spring. I'll try to post up the pics tonight.
I will also try to get a pic of the light pattern. I didn't take a before pic, and I WILL not put the sealed beams back in to get one either.
Cutting into the harness where I did is easy and unless you go with the higher wattages, the stock wires will be fine.
woodclad02-20-2006 08:53 PMH4 conversion
Todd,
I'm looking forward to the pics of your conversion and your new lighting pattern. If it is flat enough, it might not be that bad on the guy coming towards you. Since the only high-intensity headlights that seem to bother my eyes (well, ok, eye; left one doesn't work) are the blue ones, it may have all to do with how I'm perceiving the light spectrum rather than the shape or intensity of the beam anyway.
I might be interested in this conversion for myself since, with my vision, I need a lot of light to see at night -- and I can't figure out why the stupid fog lights have quit working, so driving in the rain is a nightmare.
BOTH 2-wire fog lamp unit harnesses (with EVERYTHING unplugged including bulbs) indicate a short to ground -- when they are not connected to anything at either end! I'm trying to score some not-too-costly Marchals from an '87 or earlier GW since the ones on the '87 beater never give any trouble. Any leads?
Jeff D.
casey02-20-2006 11:23 PMThis is a great cheap how to article Todd. I cant wait to do it to my Chief...then smash them on a rock at Tellico! Perhaps you can hold a clinic at our first WOT?
Green Giant02-23-2006 01:07 PMI've added the pics now. It's been a week and a half now, and I am still amazed at the difference this makes.
Tanker04-05-2006 11:08 PMWoodclad if you get the parts I'll be more then happy to help put them in with you.Its not that hard if you like working with electricity like me.I just got off my EST so I LIKE ELECTRICITY
Ridgerunner04-06-2006 10:12 AMSo where are the pics?
casey04-06-2006 12:01 PMQuote:
click on the highlighted, underlined text.
Ivan the Terrible
Old 05-09-2006, 06:22 PM
Jayrodoh's Avatar
Jayrodoh Jayrodoh is offline
Thank you grimjaw for posting about my harness' above. IFSJA members get $10 off that price. There are a number of members running the harness and I have yet to hear a complaint about them.
Honey?? What happened to the savings account? You bought a Jeep what??
86 Grand Wag Stock with Bulltear HEI
Old 05-09-2006, 06:47 PM
letank's Avatar
letank letank is offline
Hella H4 w relays (hi, low) and fresh wires from battery. And a spare light bulb in a plastic container for those surprises black out, it beat carrying a whole headlamp. You can replace the plastic socket too....
It really helped me w the upper angled beam to avoid that cow standing on the highway.....
Michel
Old 05-09-2006, 07:47 PM
Grimjaw's Avatar
Your harness is on my wish list for my J10, Darn that a long list, thats not getting any shorter.
Ivan the Terrible
Old 05-09-2006, 09:15 PM
Spectre's Avatar
SilverStars plus Hella 550 driving lights on my GW:
Old 05-09-2006, 09:23 PM
JeepStew's Avatar
JeepStew JeepStew is offline
the picture speaks LOUDLY
thas an awesome example.
JeepStew A-K-A DJ
1) SOLD:1980 jeep cherokee laredo WT 2 door 360, 727 TC, np 208, AMC 20 and Dana 44
2) SOLD:1995 jeep grand cherocar 318 awd
3) SOLD: 1989 Jeep, Grand Wagoneer "Wagonmaster" 360 ci 727 TF, Np 208, 4" lift.
4) 2001 Jeep Cherokee Sport 4.0L 2wd
pics:www.flickr.com/photos/31358907@N02/sets/72157612509481422/
Old 05-09-2006, 10:42 PM
jsinajeep's Avatar
headlight converison
I got mine on ebay. Did the heavy wiring and relays ,everthing. When I got the new light they looked good.Got checking and they had the 60/55w blubs that will give the 130/100w brightness with the diamond cut lens [if you can beleive that]. The instruction said you can use the your regular wiring[why not with 60/55w blub]. I have the 77 Chero so I got the one with the flat glass lens and they do look good. One of these days I will get the brighter blub for it.
