Old 04-10-2015, 07:54 PM
TBT TBT is offline
Left Rear Upper Shock Mount Repair
I've search for an answer on the forum and couldn't find an answer. Any thoughts on repairing an upper rear shock mount. The nut froze and twisted off on me! Thanks.
Old 04-11-2015, 11:13 AM
acct21's Avatar
acct21 acct21 is offline
Pretty sure they're the same as the '87+ TJ rear upper mounts -- which you can still buy new. You can either cut the stud off and weld it in place of your broken one, or cut off the mounts and install a new one.
Old 04-11-2015, 08:48 PM
TBT TBT is offline
Thank you. I'll give that a try. I was hoping for an easy fix, but you know how that goes!!
D60 shock mount question 76FSChief General FSJ Tech 5 11-02-2011 06:04 PM
Front shock lower mount re location?!? Dagz_07 General FSJ Tech 6 04-23-2011 10:01 PM
Rear Shock installation zbethem General FSJ Discussion 3 04-19-2010 11:20 AM
D60 Shock Mount Help/ Picture request chuckchili General FSJ Tech 11 11-10-2008 02:34 PM
Raer shock mount ?? scannman70 General FSJ Discussion 1 06-08-2008 08:34 PM
