Old 05-11-2013, 02:54 PM
Overkill SC's Avatar
Overkill SC Overkill SC is offline
A little riddle for everyone....
So, when I finally got the 401 assembled and wiring half done, I was so excited I started it up before putting trans fluid in. When I had the engine out, I replaced the front Torque converter seal, pulled the modulator to check it, and pulled the shift shaft to replace the seal. I only ran the engine for about 1 minute.
When I had everything buttoned up and all the fluids topped up, I started it for the second time. Warmed it up and checked trans fluid, all looked good.
So I jumped in and put in in reverse. Nothing.
Put it in drive. Nothing.
L2 and L1. Nothing!
Back to reverse, nothing! Chief won't move an inch!
Went to put it in park and it was grinding. Had to shut it off to get into park.
I have it working now. I'll give a big thumbs up to the first one to correctly guess the problem.
'79 Cherokee "Super Chief": 401!, TH400, part time Q-T, 33-12.50s
'79 J-10: 258 Clifford power, 3 sp man, 31x10.50's "Member, FSJ Prissy Restoration Association"
'85 J-10 RIP
'67 J Truck - anybody need a 327 or other parts?
327 with rebuilt heads. Ran a long time ago. $200, I'll help you pull it.
Old 05-11-2013, 02:58 PM
tcase in neutral?
t-case in n. or drive shaft off
Old 05-11-2013, 03:01 PM
superman0094's Avatar
superman0094 superman0094 is offline
Originally Posted by joe
tcase in neutral?
THIS!
'74 J10 w/ '76 360 30 over T18 Cooper MTT 35s
MSD 35859 8.5MM
MSD-6425 6AL DIGITAL BOX
MSD-8227 COIL
MSD-8414 CAP-A-DAPT
MSD-8869 ADAPT HARNESS
Edle 2132 Cam
Edle 1406 Carburetor
Edle Perf RPM Intake Manifold
Flex-A-Lite Variable Speed Fan Control
Dual Elec Fans
Old 05-11-2013, 03:55 PM
mattparliament's Avatar
mattparliament mattparliament is offline
Ha! I can see the look on your face when you had your "moment of clarity" and realized that!
1976 Cherokee 401 Quadratrac
4" Rough Country Spring lift 31" tires
All MSD ignition system
EZ EFI status: Running Smooth!
Dakota Seats
Powertrax No-slip lunchbox rear locker
Amp meter delete
Two Wire 94Amp Alternator upgrade
Old 05-11-2013, 04:48 PM
to all!
Oh sure. It's easy to figure out when you're sitting on your couch.
I was so convinced I screwed something up with the shift shaft that I pulled the pan. Didn't find anything wrong. Scratched my head and quit for the night. Next day the lightbulb went on. I classify it as paranoid tunnel vision after a long day in the shop.
It was a pretty good feeling when I got it back together and it moves just fine!
'85 J-10 RIP
Old 05-11-2013, 08:38 PM
kntemplars's Avatar
kntemplars kntemplars is offline
The exact same thing happened to me. Just had my nice and shinny new QT installed, brakes completely redone (master cylander to rear drums) drove almost a mile to the first traffic light which turned yellow to close for comfort, no worries new brakes, slammed them pretty hard with no skid. My nice, safe, quiet ride was going great until the light turned green. Nothing. Turns out in my panic my right foot hit the high-low lever. Scarey scarey. I thought the old TH400 bought the farm!
engine riddle.. I'm stumped! jobri478 General FSJ Tech 23 12-20-2011 07:16 AM
Engine riddle chef General FSJ Tech 33 03-26-2011 05:34 AM
Riddle me this, Batman AMSting General FSJ Tech 11 03-16-2009 08:50 AM
Wiring Riddle, seriously etjeep General FSJ Tech 5 07-13-2007 07:39 AM
Riddle me this, Bat......people, NP229 question 710 Burner General FSJ Tech 4 11-22-2006 11:39 AM
