Old 03-08-2013, 03:37 PM
FMSINC's Avatar
FMSINC FMSINC is offline
Late 70s Early 80 QuadraTrac VS 4WD
Hoping to get some clarrification here from Yous experts!
Is Quadratrac full time four wheel drive?
My 1985 J10/258/Auto has a lever under the seat for engaging 4WD (I think), is this QuadraTrac? It used to have a vacuum switch mounted under the dash too.
What set up is this and how does it work?
Thanx in advance for any help!
Paint Side Up!!!!
1980 J-10, Successful Heart Transplant 2016...360-V8, TF727, NP208, Had to have a "Brow" and Moved Over My Plow!
1985 J-10, 258cid-I6, TF727, NP229, Rusty But Trusty! RIP 12/1/16
Old 03-08-2013, 03:49 PM
1. yes.
2. no,selectrac. vac switch engages 4x mode,lever engages low range,accessible only when first put into 4x mode via the switch.
nc wagoneer's Avatar
nc wagoneer nc wagoneer is offline
if its an 85 it was most likely an np229 swapped to an np208 with a flag shifter near the seat, this offered 2hi 4hi (on road) and 4low lock. you most likely have an np208 or np219. If you have a 2wd 4hi lock and 4 low lock on the lever than its an np208 and np 219 was only used in 80 and some 81's but was still branded as "quadratrac" it had 4hi (on road) 4hi lock and 4low lock
"BROWED AND PROUD"
Old 03-08-2013, 04:05 PM
Most likely you are close but very likely wrong. This is not that helpful. Try again.
Old 03-08-2013, 04:25 PM
All quadratracs are full-time transfer case (no 2WD mode). The original(73-79) "real QT's are Borg Warner tcases, the later 80-82 also called QT's (marketing label) are New Process NP219 tcases. In an 85 GW most likely it's a NP229 tcase(Selectrac) which is a full-time/part-time tcase (it has a 2WD mode) The 2wd/4wd selection is made via a dash vacuum switch and associated vacuum plumbing. The H/N/L range functions are selected via a mechanical flag lever mounted near the floor off the side of the tunnel. Only other tcase option in 85 was the part-time NP208 tcase(Commandtrac). Mounted behind an AT all the 208 modes (2H, 4H, 4L, N) are controlled by a mechanical flag lever similar to the 229's H/L floor lever. A factory 208 will also have come stock with manual unlocking hubs. I'm betting yours came with the 229 vacuum tcase but folks get scared silly with vacuum stuff a 208 swap is common. If yours was swapped the vac dash lever has prolly been removed and the orig H/L lever now controls all the functions of a 208. Crawl under your car an look at the round tag on the tcase it'll tell you what it is. If missing look for vacuum lines going to a vac motor mounted on the tcase.
Old 03-08-2013, 04:33 PM
serehill serehill is offline
Gone,Never Forgotten.
Really
Assuming is not good. Crawl under the truck look for the round red label on the back on the transfer case & read it. Probably a 229 maybe a 219 or 208.
Most likely & original 229. In reality it could be anything. There is no other way to know what you have without looking. We could guess all day. What would probably come of that is a fried T/C. Seriously it's not somethig to guess at.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 03-08-2013, 07:40 PM
I was on my way out and didn't get in the low range flag shifter for np229's and 70's qtracs, with so little time I shoulda kept my nose out of it but I couldnt keep my mouth shut
"BROWED AND PROUD"
Old 03-09-2013, 01:13 AM
ThaCrabapple's Avatar
ThaCrabapple ThaCrabapple is offline
The 70s Quadra-Tracs in Wagoneers do not have low range.
1979 Jeep Cherokee
AMC 360(Edelbrock everything...)
TH400 Hurst Shifter
6" Lift
35s
Beauty.
Old 03-09-2013, 01:30 AM
Not all of them do since the reduction box was an extra cost option. The QT w/o reduction box is the model BW1305. The 1305 with the optional low range was sold as the model BW 1339. Don't know this as fact but from what I've seen I'd bet there were more sold w/lo range than w/o.
Old 03-09-2013, 09:09 AM
I've seen more waggys than not with the early Quadra Trac had low range. My 79 will beg to differ
"BROWED AND PROUD"
Old 03-09-2013, 09:20 AM
This thread is a train wreck.
Old 03-09-2013, 11:21 AM
crazydog's Avatar
crazydog crazydog is offline
Amen brother.
1967 J3500 - Making plans
Old 03-09-2013, 11:27 AM
Ghinmi's Avatar
Ghinmi Ghinmi is offline
Super Moderator
x3
Old 03-09-2013, 04:31 PM
x4, I'll take the blame on this one
"BROWED AND PROUD"
Old 03-09-2013, 11:08 PM
the original Honcho's Avatar
What's that smell??
Lol
1980 Jeep J-20
1979 Jeep J-10 Honcho
1991 Jeep Grand Wagoneer
Unknown
1968 Plymouth Satellite
1978 Camaro- back in action
Old 03-09-2013, 11:12 PM
OK
What kind of T/C did the train have?
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 03-09-2013, 11:21 PM
kntemplars's Avatar
kntemplars kntemplars is offline
I almost never know what the heck I am talking about but on this I am sure.
As stated above BW 1305 v. 1339 is a fact. I have a 1339 and it most certainly has the low range. Now time for my shameless plug; the low drive is unbelievable, been stuck many times, but thanks to that lever under my seat I almost always get unstuck!
Old 03-10-2013, 07:04 AM
NP200
Old 03-10-2013, 07:28 AM
This board is a train wreck...April 6, 2014.
Old 03-10-2013, 07:31 AM
Is that the "official" wreck???
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
early vs late t-18 Q's uglyjeep General FSJ Tech 0 03-05-2010 10:14 PM
Lubricant change for QuadraTrac fulsizjeep General FSJ Tech 4 09-16-2009 03:49 PM
mix match of early and late AC parts brubakes General FSJ Tech 3 07-16-2009 06:51 PM
Is this an early or late brush guard? seventynine General FSJ Discussion 6 05-11-2009 09:07 PM
Early Vs. Late V8 water pump fsj1978 General FSJ Tech 1 08-31-2008 09:08 PM
