Old 04-11-2022, 05:07 AM
honcho79360's Avatar
honcho79360 honcho79360 is offline
79 j 10 360
working on My 79 J-10 Honcho, cam gear got eaten so I'm replacing the front of the motor, cam gear, timing chain n gears cover oil pump n housing. dropped pan as well put t back together today to only find out the PROFORM cover I purchased want allow the dizzy to go in (too tight) even tried another dizzy and the same thing. sticks on the first collar. Can I sand down the collar for it to fit ?? Don't want to take it apart
Old 04-11-2022, 09:11 AM
Painful, but I would return the cover. Defective.
There is a helpful thread about checking the machining on these covers before installation. http://www.ifsja.org/forums/vb/showthread.php?t=183822
Old 04-11-2022, 04:45 PM
SC/397's Avatar
SC/397 SC/397 is offline
I won't use a after market timing cover unless I have to. You are better off using a used one. Why did you change it out?
Also, did you correct the oil passages through the new timing set?
The Squeaky Wheel gets replaced in my world
Old 04-25-2022, 05:10 AM
i changed dizzy and didnt change out the gear on dizzy, it ate cam gear. so off with everything on the front of engine and the oil pan. got one black rod next to center main, lots of end play or thrust. ive took material off dizzy now it want mesh w oil pump and drop in. new gear on dizzy makes rotation very tite on dizzy. oil pump cover is comming off to aide in dizzy drop.
Old 04-25-2022, 08:59 AM
SC/397's Avatar
The distributor should drop right in without taking the timing cover off.
Good Luck.
Old 05-03-2022, 05:14 AM
yes this is true, I think the oil pump cover so I can turn SHAFT so it drops in or just remove the oil pump shaft till dizzy drops in HOPEFULLY
Old 05-03-2022, 05:17 AM
WISH Id known this was a issue prior to My discovery of this crappy issue
WISH I KNEW OF THIS ISSUE
AMC 360 to CJ 5 Swap CJ Runner Off-Road FSJ Tech 4 10-31-2008 10:52 AM
AMC 360 cam gear issues Cartman General FSJ Discussion 1 10-20-2008 07:00 PM
will a 2barrel carb off 360 fit 304? Robber80 General FSJ Tech 7 05-03-2006 06:39 AM
a few questions swapping out 360 in 401 roadgrime General FSJ Tech 3 04-03-2004 05:49 AM
360 better than 258?? Scruffy Engine 6 07-24-2000 08:04 AM
