Like Thomas said, as long as the Wagoneer is not a celebrity-quality example, a straight across trade for the J-truck is a no-brainer, at least IMO. J-trucks in good condition are scarce. The 258 and automatic (TF999 I believe) will be rather pokey though. Good swap material, IMO.
HELLO...new guy and soon to be J10 owner w pics!
Welcome. Nice jtruck. Sounds like you have a solid plan. I'm on the side of keep the six and go for a stroker if you really want to do something under the hood!Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
what are the specs on that XJ?Austin
Originally posted by rustywagoneers_comi am not an addict, i can stop anytime.
Originally posted by altrocker1ha...thats my buddys xj. its on 6.5" of lift, 35's and long arms. open d30/44 on 4.88 gears. doorless and dead sexy...
my xj is on 4.5" and is my dd...245k. cant beat a 4.0Austin
Originally posted by austinaubinoeIve got 160 in my 4.0. Cant beat an Aw4 either, they take abuse! Mine is sitting right at 6.5 inches, Locked 60/60 5.13's and I just went doorless last summer!
Be sure to clear out those idle tubes in the venturi cluster. it will make a world of difference on the carb and idling/running in general.Andy
'81 Cherokee Laredo W/T 258/Weber 32/36 DGEV/HEI/176/208 AMC 20/Dana 44 3.31 gears
Status: Work in progress Miles: Less than 140K (as of the talk with the original/previous owner) "The Jeffrey"
Build Thread: http://www.ifsja.org/forums/vb/showthread.php?t=151814 New pics: 5/18/12
Originally posted by altrocker1pulled the j10 into my storage/workshop area today.
game on....
its going to need a carb rebuild and a full tune up. got some money right now, so i'll be getting some parts soon! cant wait.
the shop floor is going to be wet tomorrow...
The Falcon ... 73, 360, TH400, D20, D44 3.54 (F&R), 6" BJ's spring lift, 35"
"I've fought tougher men, but I really can't remember when."
Originally posted by Dr. MarneausP.S. those are some beeftastic bumpers!
http://www.ifsja.org/forums/vb/showthread.php?t=151753
Originally posted by Logans RunWhat is all that white stuff all over the place?Andy
Originally posted by bruner1981jpceI hear its something like shaved ice, but it falls from the sky
i about fell on my face 3 or 4 times pushing it into the shop with my brother. its a little heavier than the xj.
i usually go to napa for xj parts, so im headed there tonight to pick up a carb kit, tune up parts and some other stuff. it appears that new floats only run about 5-10 bucks so i think i might pick one up as well. i just need to get her running right so i can move it without killing myself on the ice! then i am going to start to dismantle bit by bit
and away we go
no turning back now
and for someone who is not well versed in 80's engines...what exactly does this guy do? obviously its supposed to have a belt connected to it, but currently it does not.
As for the belt driven component, judging on its location, since it doesn't look much like mine, i'd say thats the smog pump. You can verify that by looking on the back for a fairly thick hose leading to a diverter valve on the opposite side of the valve cover.Andy
