Old 11-04-2018, 11:03 PM
GWNashville's Avatar
GWNashville GWNashville is offline
Gas Tank for Sniper EFI
I'm adding sniper EFI with Hyper Spark Distributor and looking at replacing the fuel tank. Does anyone have this setup ? My fuel tank has a leak. Any suggestions for a new Fuel Tank?
Richard
GWNashville
Email:alexhanmusic@comcast.net
1989 Grand Wagoneer 360 c.i.
727 Transmission
Sniper EFI Hyperspark
Serehill Rear Glass and Fog Light Harness.
Old 11-09-2018, 10:34 AM
acct21's Avatar
acct21 acct21 is offline
No replacements are available that I'm aware of, but plenty of folks have good pulls to sell.
Curious as to your leak. Leaks when full? Leaks all the time? Sometimes the vents get plugged up and the tank pressurizes and leaks out through the front vent grommet -- but you would probably only notice that when the tank is full, or if you've been offroad.
Old 11-09-2018, 03:53 PM
Definately leaks when its full. Getting ready to remove it and see what the problem is. Thanks
Richard
GWNashville
727 Transmission
Old 11-09-2018, 05:56 PM
acct21's Avatar
If it only leaks when full, then I would bet you have plugged tank vents, and/or bad rubber tank vent grommets. Both the tank vent and grommet are available new.
Old 11-09-2018, 05:58 PM
acct21's Avatar
I just put a Sniper EFI on my '90, and I used a surge tank from RobbMc. It has the high pressure pump in a ~2qt can, and is slosh-proof. I installed it under the hood where the charcoal canister used to live. No need to upgrade your tank, or build any type of high pressure pump rail underneath your rig. I can't recommend the surge tank method enough.
More Dual Tank Questions Pancho General FSJ Tech 5 04-15-2015 06:44 AM
42 Gallon Suburban Fuel Tank Installation (With more Pics!!!) Wagoneerlover General FSJ Tech 42 09-14-2010 08:34 PM
Fuel tank locations and plumbing... Metal Twister General FSJ Tech 3 11-08-2009 05:06 PM
Gas Tank and Filter Sock Woes The PIG Smith General FSJ Tech 13 06-16-2008 10:09 AM
That leakin gas tank noah's big truck General FSJ Tech 11 04-02-2002 01:38 PM
