  #261
Old 09-25-2021, 09:47 PM
78 WIDETRAC's Avatar
Originally Posted by inkedmonkey
I love the 58. Sixes are pretty common around here. I have a few laying around. Hope you can find one in the NW.
Inkedmonkey I'm not searching too hard yet.
Old 09-25-2021, 09:49 PM
Originally Posted by JPSwapMohn
I had a 58 Apache that I pulled out of a farmer's field outside Boise ID, got it running and used the heck out of it. Intended to restore it but just kept using it. That 235 did just fine.
There was a guy in Boise that had a really well worked 235 (cam, dual carbs, header, etc). Sounded awesome and would lay a nice double line of rubber when he got on it. Surprised a lot of folks!
I miss that old beat up truck. The guy that bought it couldn't hand me the cash and get it on his trailer fast enough. I was sick..
This one has been in a field in western Washington based on the berry vines and serious mouse house in the bench seat.
Old 09-25-2021, 10:00 PM
Back to the build.
I got the tank installed and plumbed today. I'll fire it up tomorrow and attach the fuel sending unit.
I have a good leak from of the transfer tail shaft mating gasket. Is it a big deal to just unbolt it and slide it back so I can hit it with some permatex, Or should I remove the rear output shaft to install a new paper gasket?
Old 10-17-2021, 05:09 PM
Little more progress. I went back over all of the bolts on my suspension since installing the 4" lift. Drove it to the gas station to fuel up the new rear tank. My gas gauge is working now! I was working on my other project and kept smelling gas coming from the jeep. I looked under and found this!
It is leaking from the factory hard line. It was behind the factory tank until I deleted it. Good thing I did.
Question? Would you replace it with a new hard line or rubber reinforced fuel line?
Old 10-17-2021, 05:40 PM
goldhammer's Avatar
goldhammer goldhammer is online now
I'd probably replace the entire hard line. Then it'll last another 40 years
That's what I get for letting it sit so long. The hard brake lines on the GMC motorhome are about to start that. New complete kit is over $700. Going to be next owner's problem. Since my lady passed away in July, have no need or desire for it. She bought it cause she hated tents, and now my camping days are over.
It's hell losing two life partners in less than seven years. This one was actually my first wife, and we reconnected four years ago
Art
ASE Master Collision Tech
Old 10-18-2021, 03:22 PM
When I was doing my EFI install babywag recommended nylon fuel line. It is pretty easy to work with, light, and pretty cheap.... as long as you have no sharp bends to make. I would definitely NOT use rubber but nylon or the green'ish metal line would be my choice.
Old 10-20-2021, 03:02 PM
Sorry for you loss Art.
I've got some new stainless hard line coming so hopefully it will last another 40 years.
Old 10-20-2021, 03:06 PM
Rang I was thinking about the stout fuel injection rubber fuel line. I settled on Stainless hardline. Best to keep as much ridgid piping under there.
Old 10-20-2021, 10:42 PM
goldhammer's Avatar
Thanks. I remember that yellow one on Spicer, and wondering about it. IIRC there was a blue one there too. Think it's gone now too but haven't been that way for awhile.
Art
Old 10-23-2021, 12:59 PM
The Yellow one is up in Rochester Washington and the blue one moved from Spicer rd also, but it's still in the valley.
I found the wiring for the domes finally. It was tucked away.
Old 10-23-2021, 04:29 PM
goldhammer's Avatar
That's good on the wiring. Only thing I remember about Rochester was a cinder block shop building on the main drag (before the hwy reroute). Had a raft of Nash Metropolitans in various states of rust, most worse than eastern snow belt FSJ's. Wiife wanted one with a Toyota 22R with 5 speed transplant. Never found a decent shell in my price point.
Art
Old 12-02-2021, 08:59 PM
The dome harness had to be cut down because juice was not flowing from one end to the other in it's current state. I have to figure out if I'm going to use the LED light strips in addition to the factory domes.
I also finally received my gasket kit for the transfer case so I can seal up that pesky leak on the tail shaft housing.
I have to check the front driveshaft. When I seperated the front slip yoke things were fine, After I put it back together it is really loose. My plan is to remove the slip yoke again, clean it up and re- grease it. I don't want to just pump grease into it.
I took it for a short drive just to keep stuff moving.
Old 12-02-2021, 11:22 PM
goldhammer's Avatar
Driveshafts.....check the joints on the rear one. I popped one and replaced, got it home, and never got around to greasing it. Only whatever was in it in the box. Don't think I drove it over a mile after replacing.
The lift may have something to do with the slop in the front one.
Art
Old 12-18-2021, 10:55 AM
I have less than 10 miles on it since I picked it up from you. I will pump some grease in it.
The shaft was fine even after the 6" lift went on it. It was only after it was pulled apart for the FSSR install.
I don't have a garage to work on it so I will look into it more if the rain lets up and my motivation picks up.
I honestly need to trust the sniper system and just bust out the AAA card if it fails on me. It also bums me out that I need to get this thing through smog up here. I'm sure it will pass but Damn! It's not a daily driver!
I'm also questioning if I put the timing chain on correctly, mostly because of starter kickback.
I just put it in the same position I thought the old one was in.
If I remove the timing cover to do that, I might install a new cam shaft. Stock grind or maybe an RV type. We'll see.
Old 01-13-2022, 02:19 PM
I'm home sick today, so I took it for a ride.
The heater is working great the gauges are all reading properly, I really need to get these floor pans patched and get the interior back together.
There is one stubborn seat belt bolt in the floor that I haven't removed yet. It is a nice wet day, it helps me see the routes water is getting in. Mainly kick panel fresh air vents. I have them removed. I want to seal them up, but I know I shouldn't.
Azusa off-road videos, pics, and Cherokee review PlasticBoob General FSJ Discussion 12 10-23-2007 05:48 PM
1979 TH400 to 1981 NP208 in 1981 Cherokee 81_BigChief Off-Road FSJ Tech 8 02-19-2006 01:27 AM
1981 Cherokee Chief (Canadian) - Levi Dome Cherokees 0 08-21-2005 12:37 PM
1981 Cherokee Laredo - Tom Anhalt Dome Cherokees 0 08-21-2005 12:36 PM
1981 CHEROKEE FOR SALE - $1800 barillms General FSJ Tech 1 10-02-2002 08:27 AM
