Old 11-19-2019, 07:16 AM
Rusty76 Rusty76 is offline
Intake Manifold Part identification
Ok so I'm trying to fill holes on this manifold from my 360.
The bit that attaches to the passenger side rear of the manifold , what is it called?
Has some tubes/coils that when bolted down go into the manifold. Almost like a heating element. Block heater? did I just answer my own question..
Its crusty and I need to order a new one.
Thanks
Old 11-19-2019, 07:51 AM
78 WIDETRAC's Avatar
Choke heating tubes. Do you need them or just want to block them off?
Old 11-19-2019, 07:59 AM
love this forum. Not even done my first coffee and my question is answered!
Choke heating tubes. Hmmm. Will have to do some reading first. Dont know if I need them? I like the sound of blocking them off. First need to figure out what they do. Will be a lot easier now that I know what they are called. I live in a place that has winter but no emissions stuff needed yet. Need to do some reading.
Thanks 78 WIDETRAC
Old 11-19-2019, 08:59 AM
If you are going to stick with the Motorcraft 2100/2150, keep it! Take it out, clean it, put it back in with a new gasket. You should have a metallic tube coming off your choke element that goes to one side of it and the other side goes up to the top of the carb to get clean air (but that side is not all that important).
The heated air that comes through there, along with the electric choke element work together to open your choke faster.
If you do not have the tube coming off your carb, go to any McParts and ask for a "Choke Stove Kit" and it will come with the bits and pieces to hook it up. Should be well under $10 and it really helps with the way your engine warms up.
I was looking for some good pictures and came across this link with good info and fuzzy photobucket pictures.
https://www.ford-trucks.com/forums/8...-answered.html
Intake manifold question CommanderChaos General FSJ Tech 21 01-31-2010 09:27 PM
changed intake manifold now runs rough wont idle, TX silvercert General FSJ Tech 2 02-15-2009 04:04 PM
Performer Intake Manifold on 401 Johnny&Midge General FSJ Tech 21 12-30-2008 11:37 AM
intake manifold problem robertmkec General FSJ Tech 12 09-22-2003 03:13 AM
Is my intake manifold screwed up? Thomas DeBusk General FSJ Tech 7 04-16-2001 08:50 AM
