Old 01-28-2020, 02:45 PM
mwood65's Avatar
mwood65 mwood65 is offline
It works for the first time in years!
Thanks to JSinajeep I now have a working fuel gauge & wiper switch!!
Been guessing at fuel level for 7 years and now it all reads correct!!
Thanks man!
Old 01-30-2020, 12:36 PM
YYyyyeeesssss!!!! It's the little things in life that make things great! Glad it worked out! You have a new gas tank in there, too, right?
79 Cherokee Chief
Old 01-30-2020, 04:50 PM
jsinajeep's Avatar
jsinajeep jsinajeep is offline
Thanks man!
Glad it all worked for you
Old 01-31-2020, 08:30 AM
great news
jsinajeep has helped a lot of folks here.
Old 01-31-2020, 08:37 AM
Originally Posted by SOLSAKS
great news
If your FSJ is on the road, chances are jsinajeep has supplied parts for it! He is a star!
79 Cherokee Chief
Old 01-31-2020, 04:50 PM
" now i just gotta get the motor put back in it!"
Old 02-01-2020, 02:31 PM
mwood65's Avatar
Yes, I put the new poly tank in with a new sending unit and hoped that would fix the problem but the gauge was still wonky. Changing out the gauge with the replacement I got from JSinajeep fixed it finally!
Old 02-09-2020, 12:50 AM
mwood65's Avatar
Fuel gauge....... works 100%
Oil pressure gauge..........20psi @ idle / 40 psi at 2500 rpm
Amps hold steady at 40 (not sure that works right)
Temp. gauge works correctly
Speedometer works
What else can I ask for?
Old 02-18-2020, 01:30 AM
bagusjeep bagusjeep is offline
A voltmeter?
Old 02-18-2020, 11:28 AM
Rusty76 Rusty76 is online now
Nice work!
Old 03-13-2020, 10:24 AM
nograin's Avatar
nograin nograin is offline
Not right!!!!!!
Amps should zero. ZERO!!!
That's a Danger Danger Will Rogers big time.
Note which way it reads, charge or discharge, and then shut it OFF.
Turn key to run or accessory without starting and quickly not what it shows.
Shut it off.
Time to trouble shoot.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Old 03-13-2020, 01:16 PM
It will read that with a discharged battery and or right after cranking till the battery is charged. Was it reading this after a fully charged battery and running for awhile?
First time poster EasTXJEEPER General FSJ Discussion 21 08-08-2012 08:00 AM
What to do before trying to start a rig for first time in 3 years??? Dmntxn77 General FSJ Tech 18 06-21-2006 09:04 PM
part time conversion w/o hubs rusty401 Off-Road FSJ Tech 2 01-20-2005 07:35 AM
QuadraTrac - Full Time or Part Time uglyjeepling General FSJ Tech 11 08-09-2004 04:22 PM
GM HEI vs. Motorcraft/Duraspark ignitions (very long) Sycho15 General FSJ Tech 11 09-06-2002 07:46 AM
