Old 05-25-2019, 07:25 AM
FlashGordon's Avatar
FlashGordon FlashGordon is offline
Pictures from your 4-speed column shifter indicator
Before I start the project to swap in a 4-speed transmission I would like to see your solution for the new column shifter indicator.
Would appreciate to see one or two pictures if possible...
(so far my nterior is 100% stock and I would like to see how different a 4-speed column shifter looks like ...)
I know I asked already in an earlier post but I still do not know:
Does it make a difference -- only regarding the new column-shifter-indicator -- if I go with a 700R4 or a 4L60e?
Old 05-28-2019, 11:46 PM
I have nothing to add. Just subscribing to see what you find.
Old 05-30-2019, 09:21 AM
ProTouring442's Avatar
ProTouring442 ProTouring442 is offline
I used a unit from a GM van. It matches the unit in our Jeeps, but with OD.
"There's just no use arguing with stupid people." -Thomas P. Elliott
automatic steering column shifter Magnum CJ General FSJ Tech 1 10-14-2005 08:25 AM
Floor shifter and nix the column shifter? Bluesky4x4 General FSJ Tech 1 10-01-2002 05:16 PM
Column shifter travel, not enough to shift tranny all the way into 1st barillms General FSJ Tech 0 06-12-2002 01:44 AM
Column Shifter C. Poole General FSJ Tech 1 01-23-2002 02:11 AM
90 GW Column Shifter trouble Puslinch General FSJ Tech 1 09-02-2001 10:18 AM
