Old 09-23-2007, 01:45 PM
Mahamotorworks Mahamotorworks is offline
1977 Wagoneer Mostly Off Road Rig
That plans for my 77 waggy are to make it a mostly off road rig. I have knuckles and high steer arms on the way. I know I want to change the tranny and get a Dana 300 twin stick T-Case to go behind it. The interior consists of the dash, front seat and door panels. There isnt much else interior wise in it. I am in the process on getting a SOA/RSF kit for it. That will be going on when I get my 89 running correctly and can drive it to and from work.
I know I want to make it push button start and change to MSD Ignition on it. Since I am replacing the Tranny and T-Case I might as well get a better motor. I could go with a 401.
I know that when I am done I want it to be street legal. My question is how far should I go?
Input is appericated, I woud like to see what others have done to their mostly off road rigs.
MAHA
Old 09-25-2007, 07:39 AM
shadowjeep's Avatar
is something wrong with the 360? if not i would hold off on taking it out and putting a 401 in until you find one. 360's will surprise you. it may difficult to keep it street legal for long. it sounds like you got a good rig to start with and have some good plans. just remember to take plenty of pics.
Rick C.
www.kymc.org
shadowjeep
2003 Chevy Silverado
Old 10-06-2007, 10:18 AM
Ok I am in the process of getting the parts I need to lift my 77 Waggy. I am going to hold off on starting the build till I have most of the parts that I need.
Here is the plan.
I am going to do a SF and SOA lift for 7 inches of lift then I will probably add a 2" all spring lift kit on top of it. The springs that are on it now are in bad shape the dirvers front is flat. I want to run 35 inch tires on it but probably wont be able to with out adding more lift or cutting fenders. I will end up with 33X12.50R15 tire on stock 5 slot rims. For now I am going to pass on looking for a 401 for it and stick with the 360. Tranny and T-Case will stay till I brake them and desire/have to upgrade them to something else.
Talking about the parts needed to complete the lift I just wanted to make sure that I have a good list of what is needed.
I have the following either in my living room or on its way:
SOA/SF Kit from TT Fabworks, Thanks Again TAD!!
Crossover steering set up from Harsh Terrain
Extra Flat Top Dana 44 Knuckles
I have the plan to buy the following:
2 or 4 inch lift springs. I havent decided how high I want to go.
Longer Brake lines
33X12.50R15 BFGoodrich M/T or Firestone Destination M/T
Shocks
Am I missing any thing else major?
The list is in the order that I plan to purchase everything.
Thanks for the input.
MAHA
1989 Grand Wagoneer Engein Reaplacement: In Planing Stages.
Old 10-06-2007, 06:59 PM
tylerd13 tylerd13 is offline
SOA 2" or 4" spring might look funny with 33's
77 Cherokee 360/sm465/205, 1 tons, 38's
84 4runner on 35's
Old 10-06-2007, 10:17 PM
Slick Willie's Avatar
Slick Willie Slick Willie is offline
SOA with SFK will give you at least 6", probably close to 8", depending on what axles and springs you use. That much lift with 33's would be silly on a GW. But like you said, if this is an offroad vehicle only, lower with bigger tires is better.
-Will
'86 Wagoneer 360/727/Stak 3 speed/HP60/FF14/welded 4.10's/~3" Front Springs/Chevy 63's/42's/hummer beadlocks/topless/8 point cage/half doors
Originally Posted by rockjeep44
After this weekend chicks are gonna need suspenders to keep their panties up when I roll in
Old 10-06-2007, 10:44 PM
shimniok's Avatar
shimniok shimniok is offline
As far as you want, can afford, and need to, in order to achieve whatever sort of goals you've set for the truck... What kind of trails do you want to run? You want it street legal... how much does ride comfort matter? Do you need cargo room? Protection from elements? Want it quiet or does that not matter? Think through all those kinds of questions, and rank them. If you don't know what your goals are, and what features you want, how can you build a rig that fits what you really want, right? This sounds like what I posted elsewhere, but anyway...
Think about the modifications you have in mind and options available, and figure out what combination of parts / mods fit the overall goals. Put together some of the more likely candidate combinations and figure out which offers the best fit to what you want to achieve... it's all about tradeoffs, so try to find the mods that gets you closest to the most important features without giving up too much...
Michael
Old 10-10-2007, 09:30 AM
Slim's Avatar
Slim Slim is offline
Im running a 77 with a SOA in the front ,,, shackle flip in the rear ,,stock springs ,, frt and rear and 3" body and am running 38.5 with No problems ,,, Im sure u will find 33's way to small
Mine is mostly trail only and only drive it to and from the trail ,,,
77 Cherokee chief ,360 cid,quadra-trac,chopped /bobbed 12" , 8point cage, front exo ,d60frt 14bolt rear ,38.5x14.5x16.5 on beadlocks ,frt & RR winch,OBA ,SOA,shackle flip rear
** Island Rock Crawlers**
4WDABC Member
BCWF Member
Old 10-10-2007, 06:31 PM
I am sure that I will end up with 35's or bigger. I havnt looked at anything bigger then 35's. I guess I will have to take a look at bigger tire now.
MAHA
Old 10-10-2007, 10:29 PM
THANKS!!!!
I ordered a SOA/SF kit from Tad. I got it today I am really impressed, River Beast and Tad put a lot of work into this kit. I cant wait to start installing this.
I just really wanted to say Thanks to Tad and Riverbeast for taking the time to creat this kit.
I will take a lot of photos when I start to install it. It will be a long process but it will be worth it.
MAHA
Old 10-11-2007, 07:26 PM
MAHA,
I really want to thank you for mentioning RiverBeast (Todd).
Many newer members think I actually designed that rear kit, I did not.
As nice as it would be to take credit for the rear SF KIt, I never had anything to do with making it happen.
I have made some changes to keep costs down and yes, I am the one that makes them now, but that rear SF kit is very much the brain work of Todd, not me.
Thank You,
Old 10-12-2007, 09:18 AM
Slim's Avatar
Originally Posted by tadsal
MAHA,
I think many of the newer member forget alot of influence that RiverBeast had on alot of the tech and designing we all use on our FSJ;s now a days .. truely one of the Ones who shows use others how its done ...I remeber using His tech builds alot to help Me with Mine
4WDABC Member
BCWF Member
Old 10-21-2007, 08:01 PM
Ok I have been looking at my Lift and Tire options. I have been doing a lot of reasearch trying to see if my plan are going to work out at planned.
This is the plan:
(subject to change with out notice)
I am going to go with 35X12.5R15 BFGoodrich MT's on a set of 15X8 AR 767 Rims.
I am going with the SOA/SF kit from Tad. This should get me 7 or more inches of lift. I am planning to add a 2 inch lift spring on top of the SOA/SF Kit to get me 9 inches of Lift.
Looking at this page http://www.ifsja.org/forums/vb/showthread.php?t=44404
This should work. If you look under the 35X12.5 section it lists a 6 inch Spring lift and 3 inch body lift giving 9 inches of lift.
I just I am just wanting other peoples imput and what worked for them on a set up like this. I was also wondering ifa 6 inch DPA will work with my 9 inches of lift. I am going with cross over steering.
Thanks In Advance
MAHA
Old 10-21-2007, 08:12 PM
Dmntxn77's Avatar
Dmntxn77 Dmntxn77 is offline
Hey watch this...
A DPA with cross over steering will be fine. Why not high steer?
Old 10-21-2007, 08:16 PM
I Ordered everything to go high steer I called the company and told them what I was doing to make sure that the parts would work. They messed my order up amd sent me 2 pass side steering arms when I called them to see if I could swap the wrong arm out they said they dont make the driver side arms. I told them that I talked with one of their customer support people there they said that what I was doing would work out with the parts I ordered. They told me that that guy I talked to there didnt know what he was talking about and that they were sorry there was nothing that they could do. They wouldnt even take the whole order back. I know some one with a water jet so I just need to find matching steel stock and have one cut out. It will go to high steer but to get it on the road cross over will work.
MAHA
Old 10-21-2007, 08:33 PM
Mud Buzzard's Avatar
Mud Buzzard Mud Buzzard is offline
In Florida, anything with a plate on it is street legal.
592hp and 44" Vs..plowing a field near you!
Old 10-21-2007, 08:35 PM
MAHA
That's ridiculous. Send me the name of the company in a private message if you please (I won't tell anyone--I understand libel). I refuse to do business with people who put policy over customer satisfaction. In business, you've gotta have sufficient reserve capital to "eat" your own mistakes and keep your customers happy. Otherwise you need to be in a different business. Just my opinion, but that's what I believe...
Old 10-21-2007, 08:37 PM
It's got plates on it. Code Enforcement cant bother me any more.
MAHA
Old 10-21-2007, 09:03 PM
skeletor's Avatar
skeletor skeletor is offline
where are the pictures in this thread
anyway, 9" of lift and 35s would be small in my opinion, a regular soa and a sawzall would be better and could run much bigger tires. i'm guessing you dont want to change the axles thats why your sticking with the 35s. but good luck on the build.
-bryan
1984 j10 LWB
1977 Cherokee chief wide track(sold)
2004 LJ
Old 10-21-2007, 09:07 PM
Ya I know about the pics. I really havnt done any thing with it yet.
Here are the pics. Any way. I will be taking a lot of them when I get all the parts in to do the lift.
MAHA
Old 10-22-2007, 10:29 AM
rockingon24_7's Avatar
rockingon24_7 rockingon24_7 is offline
quote "Am I missing any thing else major?"
Has anyone mentioned he needs new driveshafts?
thats a pricey issue for some
1950 F1, V8-thm700 previous dd, Suzuki Bandit 600,
Dodge Dakota, it's a gray grilled white work truck kind of truck, dd
74 J-10, was the farm truck until I started rebuilding it
360/727/np241, Holley TA, SOA/SF, 106" WB, dana44s lockers, 35"mt's, winch and still much more to come.
