Old 01-15-2020, 07:32 AM
76j10build 76j10build is offline
Suspension
I am trying to figure out how much actual lift I am going to get from a given lift kit. What I mean is, I'm surey springs are sagged (1976 J10), so I am guessing I will get more than the stated lift.
1. Does anyone know stock axle to frame distance for a 86 J10? I have looked and can only find various references to fender to tire measurements, usually for wagoneers. Fender to tire is not very useful tire sizes vary widely and wagoneer body lines aren't the same asy Jtruck.
2. This may be an easier way to figure out what I want to know - has anyone lifted the front with lift springs and the rear with a block (like the rough country lift) and had the back be too low? (I figure any difference in the front and back at that point would be the amount of sag in the rear springs).
My son is considering whether to use new spring packs or blocks in the rear, and I am concerned the blocks may leave the rear low. Is this a real problem?
Suspension seats Hammer Off-Road FSJ Tech 16 01-31-2012 01:17 AM
softest/ felxiest suspension swmpdonkey Off-Road FSJ Tech 2 03-18-2011 09:39 PM
where can I get a suspension lift? (2 inch or so) Wagoneerlover General FSJ Discussion 1 04-07-2007 10:30 PM
Can I upgrade the suspension? Narnian General FSJ Tech 15 07-05-2004 03:41 PM
(TOM) What FITS and What HITS.... Lift / Tire Combos River Beast Suspension and Steering 40 11-05-2001 12:32 PM
