Old 04-20-2005, 09:19 AM
vistalite's Avatar
vistalite vistalite is offline
Unhappy
The transfer Case on my 87 Wagoneer cracked while I was driving to work today. I'm assuming it's the NP228/229. I heard a thunk like I ran over a woodchuck and pulled over and noticed a steady drip of fluid from the transfer case. I crawled under the jeep and ran my hand over the top of the transfer case and flet what I think is a crack. The fluid is leaking from the top of the case. Can I continue to drive the jeep with the busted case provided I don't shift into 4wd? Recommendations for finding a replacement transfer case would be great. Hmmmm...I guess I am postponing my Colorado trip. Thanks, Jones
vistalite = Jones Ramsey<br />87 Grand Wagoneer (stock)<br />The jeep wants to remain stock as it breaks whenever I have extra funds to buy it something nice.
Old 04-20-2005, 09:39 AM
xsonmyeyes's Avatar
xsonmyeyes xsonmyeyes is offline
I drove mine for a while like that before I figured out what it was. I would be concerned with what caused the crack too. If it is cracked on the top, it should only leak down so far and then stop. maybe while driving from slinging parts I would think. Is it on the front cover?? I have one for parts if interested.
'91 Grand Wagoneer- New Long Block 05-10 W/ Edelbrock Performer Manifold, Carb, & HEI upgrade w/Taylor wires...and lotsa CHROME!--Chevy S-10 Steering box upgrade--3" body lift--31' BFG's
2006 Harley Davidson 1200 Custom Sportster--
2008 Harley Davidson 1200 Low Sporster
'86 Chevy G20 Van
'96 Pontiac Grand AM
Old 04-20-2005, 02:38 PM
J10Mike's Avatar
J10Mike J10Mike is offline
Delightfully Incompetent
th 228 was only offered in 86. probably a 229. but, that's beside the point. this would be a good time to replace it with a 208 part time case. it's a direct bolt in. but, you will need a longer rear driveshaft from a 80 thru 83 cherokee...also depending on the engine set up.
front locking hubs are not required. but, it would take some wear and tear off the front axle.
www.j10mike.com
Old 04-20-2005, 06:57 PM
Wagonforever's Avatar
Wagonforever Wagonforever is offline
JB Weld, works great for a temp fix.
There are those that have and those that will.
1986 Grand Wagoneer, BONE STOCK just the way I like em!
The Aviation Forum
Fred 08
Old 04-21-2005, 05:13 AM
DaddyO DaddyO is offline
I think the same thing happened to me last week! But, I can't figure out where the #$#@ crack is. It sounded like I hit something under the car, and then I noticed the leaking.
Any easy way to find that crack?
-------------------------<br />1989 GW - 36k orig miles<br />All stock except for HEI<br />-------------------------
Old 04-21-2005, 09:54 AM
vistalite's Avatar
Thanks for the replies. I felt along the top of the case and noticed a raised sharp section of the case about 1-2 inches long. I will try JB weld as a temporary measure until I figure out what to do next. I did notice that the rear main seal is slightly leaking. Maybe time to deal with slightly slipping transmission as well. I need to figure out what I can sell on Ebay to raise funds for my Jeep fix-er-up project. Thanks all, Jones
And it is okay to drive the Wagoneer with the crack? Street Driving that is.
229 Transfer Case Removal-help/questions chr1s General FSJ Tech 3 10-05-2005 12:53 PM
Transfer Case compatability Steelfish General FSJ Tech 3 08-01-2005 02:35 AM
Tranny or Transfer Case Bad???-long Marshmountain General FSJ Tech 4 09-23-2003 03:30 AM
AMC/Jeep Manual Transmission Info James 007 General FSJ Tech 0 09-02-2002 07:40 AM
Transfer case Help! Chris W. General FSJ Tech 20 01-12-2002 11:22 AM
