Old 10-15-2007, 06:55 PM
malodin's Avatar
malodin malodin is offline
who all has a d300 in there bigger than a cj rig?
just as the title says i would like to know who has a d300 in any type of rig bigger than a cj? and post up experiences of your d300?
Old 10-15-2007, 07:28 PM
SCscoutguy's Avatar
SCscoutguy SCscoutguy is offline
They came in some 1980 International Scout II's which are considerably larger than CJ's especially the 118" wb Terra and Traveler models.
John
Old 10-15-2007, 07:34 PM
malodin's Avatar
your right and heavier than an fsj(or at least close to it)
Old 10-15-2007, 07:35 PM
jeeping1974's Avatar
i have one in my j10. with the clocking ring it is set flat. there is a load of space between it and the frame rails also.
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
Old 10-15-2007, 07:37 PM
malodin's Avatar
is your j10 up and running yet? just wondering
Old 10-16-2007, 08:34 AM
rockjeep44's Avatar
The Advisor
There's a bone stock d300 in this rig. He broke the case in half (was the result of a bad mount) but has never broken anything else in the d300.
Buggy Buildup
Originally Posted by welchct
Old 10-16-2007, 08:59 AM
dusty's Avatar
dusty dusty is offline
had two d300's in fsj's
one in my current chief running a 401 4.10s 33's and 5spd towing a fair amount and the other is in my old j20 with a 401 and 36's both were stock t-cases both have been wailed on the j20 is still going 15 years later in montana on a ranch pulling irrigation lines everyday and then rock crawling when not being used for that, last i heard the new owner put a 4:1 gear set in it and had up graded to a detroit in the front also but still was running stock inputs and outputs.
the cherokee has a little nicer life but still tows alot i did swap in a 32 spline tailhousing recently i did that for the oportunity to utilize the flange style CV
I like the D300 over the 205 in a FSJ because you can clock it up where as the np205 hangs down so far. also i like the size of it because that allows for better routing of the exhaust and the ability to twin stick it, FSJ's should have had twin sticks fromt eh factory.
AMC 401 supporter
GO UM Montana Griz
Old 10-16-2007, 10:21 AM
malodin's Avatar
this is what i am looking for nice clear experiences.
Thank you
Old 10-16-2007, 11:34 AM
ajbirken ajbirken is offline
A dana 300 will explode instantly if it is within 10 feet of an FSJ.
I have one in my J10. sm420/dana300 and 33's.
Old 10-16-2007, 11:45 AM
malodin's Avatar
and yours exploded?
was it stock or upgraded? was it well worn out? more story please
Old 10-16-2007, 11:55 AM
Mud Buzzard's Avatar
Mud Buzzard Mud Buzzard is offline
My J20 is equipped with a D300 that has 32 spline shafts, 1410 yokes, 4:1 kit, twin sticks, and a solid aluminum mount (1/4") to a custom crossmember (that has rubber bushings). The solid mount has been the only way I can avoid breaking ears on the slip yoke.
592hp and 44" Vs..plowing a field near you!
Old 10-16-2007, 12:09 PM
malodin's Avatar
now we are getting somewhere so far there is more people running d300's in bigger than a cj style rigs than i even thought.
Old 10-16-2007, 01:05 PM
and yours exploded?
No mine is fine. Been there for several years (although I admittedly don't get out that much).
I am just using poor internet sarcasm. I have heard soooooo many times how the dana 300 won't hold up in an FSJ.
Old 10-16-2007, 01:11 PM
malodin's Avatar
cool cool, i thought maybe you had it in and it blew up on yah
Old 10-16-2007, 04:17 PM
j vegas j vegas is offline
What about trans clearance? I remember reading something about issues hitting the pan on a 727. Are any of you guys running this trans? If so, how have you dealt with this problem?
Also, what yokes are you running?
Jared
"Contrary to popular belief, beer is not a vice - its a daily discipline." -Hank Hill
Old 10-16-2007, 04:35 PM
malodin's Avatar
i am running th400 in mine and have no clearance issues whatsover and my d300 is almost perfectly flat up inside the frame rails.
Old 10-16-2007, 04:47 PM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
I think Sambo has one in his rig too. He does some fairly serious wheeling in NM and Tx.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 10-16-2007, 08:37 PM
X2 with mine.
Old 10-16-2007, 08:39 PM
Slick Willie's Avatar
Slick Willie Slick Willie is offline
The D300 doesn't clear a TF727 tranny pan unless you have a pencil thin front driveshaft.
-Will
'86 Wagoneer 360/727/Stak 3 speed/HP60/FF14/welded 4.10's/~3" Front Springs/Chevy 63's/42's/hummer beadlocks/topless/8 point cage/half doors
Originally Posted by rockjeep44
After this weekend chicks are gonna need suspenders to keep their panties up when I roll in
Old 10-17-2007, 09:41 PM
Sambo's Avatar
Sambo Sambo is offline
i have had mine in for just over 2 1/2 yrs now and i love it!
but i would also love to add 4-1 tp it! havent broke anything worth bragging about,cept a tranny mount(which was old anyway)
i highly recommend putting them into t400 equipt rigs
i used the novak kit which is part@ 134-a i believe...well worth the money!!!
77 chero DEAD.
