Originally posted by jeepsr4ever:
where is the 401 thread?????
We got cut off, some people couldn't handle the banter and felt compelled to read/complain rather then ignore. Maybe we can keep the discussion to a level that won't offend.
Still need to examine the torque curves of a 500ftlb 401 compared to a 500ftlb 500 to see if they do compare or if the 500 builds torque faster. I think with the right cam in the 401 it might be able to match it.
The Caddy is cheaper only to a point of build, barely above stock.
Still the specs don't lie (or do they? John ran a dyno and came up with the same thing). A 401 builds almost twice the torque difference between it and the 360 in 41 more CI. The Caddy, with 99 CI on the 401 required twice the CI to obtain the same (very close) torque gain. This is comparing the lowest common denominator 401 (Jeep) to the lowest common denominator 500 ('76). If the torque difference between a 360 and 401 were negligible as was suggested then the same could be said for the 500 over the 401.
Pretty much everybody spending money to rebuild a motor is going to be buying new pistons/cam and if it's stock, putting on a new manifold/carb and if they are wise... balancing it.
Do that lil bit-o work to a 401 and you are at 500ftlbs with the right choice of cam, and you're still running a stock exhaust for low end torque while running on pump gas. What amount of torque does the same mod do for a 500, and if it does not build the torque as fast as the 401 why not?
The CI factor doesn't hold water, cost factor involved in a low level of build is definately in the 500's court.
[ December 13, 2003, 10:53 AM: Message edited by: Elliott ]
