Old 10-17-2019, 01:44 PM
KillyMcGee KillyMcGee is offline
But where do these lines need to go?
I have 2 rubber lines that come up from the back of the intake that were cut off by the previous owner. They go to a hard line that appears to go back to the gas tank. I assume these are just fuel tank vents but don't know where they need to go.
Old 10-17-2019, 02:32 PM
What year/model FSJ? What engine?
Old 10-17-2019, 03:00 PM
yes 2 tank vent lines...
hoses T together going to charcoal canister
Old 10-17-2019, 03:10 PM
85 GW, and if they charcoal canister is gone along with the air pump, the lines from the exhaust manifold to the intake etc?
When I got the truck what little vacuum lines that were left had been plugged with roofing nails. 4WD didn't work because it was routed to ported vacuum, all thermal/temp vacuum switches are completely free of vacuum lines (besides capped off ones).
Old 10-17-2019, 03:42 PM
With no smog/emission junk. Coming directly from the manifold you'll need at least a dedicated line to feed the vac reservoir ball that runs the tcase 2wd/4wd function and the heat/def doors. Another for the PB booster, another for the cruise control.
Old 10-18-2019, 11:46 AM
I do have a line to my vac ball. 4wd and cruise both work. so does PB booster. Distributor ran to ported vacuum.
At this point I'm just not sure where to run my vents. The 2 lines from the gas tank, and I think I'm supposed to have vents for the diffs. Any others? And do they just need to be vented to atmosphere?
85 and 86 GWs
Old 10-18-2019, 12:07 PM
Differentials and gearboxes are vented to atmosphere. Run the vent hoses up high and dry and bend/mount the ends over to form an upside-down "J" to keep dirt and water from entering.
Old 10-18-2019, 12:18 PM
There a transfercase vent too?
What about the gas tank vent. I traced it out when doing my exhaust, and ignorant but overly cautious me though if this is gas tank fumes I don't want it venting just opening near my engine. Thanks for the info and help so far
85 and 86 GWs
Old 10-18-2019, 01:36 PM
Your orig tank vent ran to the charcoal/evap can in the eng bay. If not running the can mount it high and dry on the firewall. Or you can terminate it closer to the tank under the wag. You don't need a hughe vent hose. 1/8"ID is plenty big. Before the evap can days the tank was just vented via a vented gas cap.
Old 10-21-2019, 10:28 PM
ZackN920's Avatar
ZackN920 ZackN920 is offline
A vapor/charcoal canister doesn't suck any power from the engine, I don't understand why people take these things off... If I were you, i'd find another canister in the junkyard that would fit in the engine bay (if your lucky, there could be a GW to take one from) and put it back in the system. It will contain the vapors and if you attach it following the diagram on the core support, it should be able to consume those vapors as well. (the engine suck's em' up when running)
...not too rusty anymore
Plenty of patina
The others
1926 Dodge Brothers Business Sedan 212 I4-CRANK START
1987 Lincoln Town Car Signature Series-5.0 AOD (WD)
1987 Dodge Dakota LE 3.9, A999, 3.90 gear (DD)
1994 GMC 'Burban 5.7, 4L60E, NP241, 3.42 gear (DD)
2001 Jeep Cherokee 4.0, AW4, NP231, 3.73 (limbo)
Old 10-25-2019, 09:02 AM
Yeah, likely acting on their ignorance. Vapor recovery has practical benefits without any loss of power or drivability, and near zero maintenance requirements.
Fuel Lines Question SamGreazy General FSJ Discussion 6 09-26-2013 08:16 PM
Replacing Brake Lines, Bleed MC? barlowchiro General FSJ Tech 1 05-24-2012 04:53 PM
'68 Wag Fuel Lines ne715 General FSJ Tech 7 12-20-2011 09:14 PM
OEM brake lines for J10 WHSII General FSJ Tech 6 03-12-2011 11:36 PM
hELP FINDING RIGHT LINES Madspeed General FSJ Tech 4 02-23-2007 09:39 PM
