Old 10-11-2019, 04:59 PM
J20 project's Avatar
Dilemma
Got a problem....perhaps of my own making but just the same....
I have been slowly building on a 80 Chero wide track for a while. Mechanically just about where I want it. 44hd/8 bolt up front 3:73 ratio, D60 disc brake ARB, 3:73 out back. Fresh, and recently well tuned 70k mile 360 w/ Edelbrock package, hedman hearders, HEI,,,,etc, etc.. All new gaskets, doesn't leak( for now). On board air, air tank, relay package...
The bad:
While pretty much rust free, the das was trash so I gutted it and have a new dash mocked up. Interior is raw and miles away.
Now the problem:
Just acquired a 87, spinnaker blue(faded) GW w/ no motor, no tcase, no axles. but again..rust fee body, interior is complete if faded.
Do I swap and attempt a GW wide track? Or should I just slowly build the GW and use the Chero as a thumper?
J20
BP Drivetrain...........
775-537-7918
Old 10-11-2019, 05:21 PM
Finish the Cherokee, once driveable make a plan and start on the GW.
Starting a 2nd project or combining two projects is a recipe for never finishing.
Old 10-11-2019, 06:05 PM
letank's Avatar
letank letank is offline
the dash and senders on the 87 are different than the 80... well you have no senders currently because no motor, but if you want to install the dash of the 87 to the 80, you will have to swap your oil pressure/coolant temp and gas gauge senders. For the 86 model and later the senders went sort of reverse on the resistance scale to the indication when compared to the 85.
As Tony said, getting motor/trans/axels... if another scavenger hunt...
Michel
Old 10-17-2019, 02:38 PM
I agree 184%.
Turn signal dilemma 1969Wagon General FSJ Discussion 4 04-13-2012 05:01 PM
nylon timing gears...dilemma seventynine General FSJ Tech 25 01-16-2012 06:42 PM
my fuel tank dilemma Austin 4x4 General FSJ Tech 3 05-24-2011 04:22 PM
Bed Dilemma Knuck General FSJ Tech 23 05-05-2009 10:59 AM
Driveshaft Dilemma. trail mule Off-Road FSJ Tech 10 05-29-2008 03:29 PM
