Old 01-12-2019, 11:42 PM
Does my check engine light need a ground or 12v?
Every diagram I see for TBIs just shows a line to the Check Engine/Service engine soon/Malfunction Indication light. I assumed the computer applied 12v to light the light. Or do I apply 12v to the light and the computer grounds it to turn it on?
Old 01-13-2019, 09:00 AM
I believe it is ground switched. not 100% sure on yours.
Old 01-13-2019, 10:45 AM
This ^
You sure you don't want to break in your new engine w/ a carb before experimenting/debugging a TBI install??
Old 01-13-2019, 08:06 PM
HAHAHA!!! I am definitely making your point for you, aren't I! LOL!
Old 01-13-2019, 08:57 PM
@ minimum should monitor data to try and make very certain it isn't too lean.
too lean and you risk chewing up cylinder(s) and/or piston(s).
what is your plan on a .bin?
Old 01-13-2019, 10:33 PM
Curly5759's Avatar
Curly5759 Curly5759 is offline
PCM is the ground for the light. Back in the day, when we wanted the CEL to flash codes, we would put a jumper wire between socket A and B on the ALDL (Assembly line Diagnostic link) It's called the DLC on OBD 2 vehicles.
77 Cherokee S 360/TH400/QT
Old 01-14-2019, 10:33 AM
Will do. I downloaded ProTuner this weekend and am watching videos on how to use it.
.bin: I have one computer from a stock 95 350 and also bought this setup:
http://www.ifsja.org/forums/vb/showthread.php?t=186447
He had it on his 440 which is very similar to my build: Similar cam, similar compression, headers, timing control, etc. I know I will need to tune but his .bin should be in the ball park for me and close enough to break in the cam? I am using his injector pod now (28psi, I verified it this weekend) and computer. I hope to get into that .bin this week and see what's in there. ProTuner is all new ground for me so I have a steep learning curve. Luckily there is tons of info out there, I just need to spend the time to learn it.
Stainless steel engine bolts observation pb General FSJ Discussion 21 04-06-2007 01:00 PM
chronic ign. control module failure Magnum CJ General FSJ Tech 15 09-19-2006 09:37 PM
Tail light ground locations ArtsiFrtsi General FSJ Tech 15 02-14-2006 09:50 AM
where the HE double L doues the brake light ground roadgrime General FSJ Tech 16 01-12-2005 07:15 AM
Check your engine harness for this! Matthew W. Woodruff General FSJ Tech 0 11-18-2003 02:21 AM
