Old 03-16-2018, 05:56 PM
rayray311's Avatar
rayray311 rayray311 is offline
Window Belt Name?
Hey All,
I don't know what the name of the white plastic like belt with teeth is that slides along the rail to move the window up and down inside my driver door.
A little while ago I went to use my electric windows and the window wouldn't go up all the way....I manually forced it up then got home and looked inside and realized that white belt with teeth had broken in the middle. I was able to manually push the belt until it caught while rolling up the window but now I cant roll my window down more than a quarter of the way.
Wondering what that part if called and where I can get another one. I called the local Jeep Dealership arts department and he said they don't have it.
Thanks
Old 03-16-2018, 07:12 PM
Pyrate2010's Avatar
Pyrate2010 Pyrate2010 is offline
Power window flex rack or track
https://www.fsjjeepparts.com/j8134773.html
1983 Cherokee 4 door
AMC 360 727 trans 229 transfer case
FiTech EFI, MTA-1 cam, wiseco 9.25 pistons
Working on complete restoration with Wagoneer boobie Grill
Old 03-16-2018, 08:23 PM
Tripwire's Avatar
Tripwire Tripwire is offline
Agreed...
do NOT buy flextracks from your local parts store, use BJ's or TGW or fleabay. the parts store ones are brittle and fail quickly
BTW... you will need a torx screwdriver set to change it - cheap on amazon or harbor freight
Trip
Abort? Retry? Ignore? >
Old 03-17-2018, 02:30 PM
rayray311's Avatar
Originally Posted by Tripwire
Agreed...
Trip
Is it easy to do? seems like everything u think will be easy turns into a PITA
Old 03-17-2018, 05:32 PM
DukeJeep's Avatar
DukeJeep DukeJeep is offline
It's pretty easy, it just slides on a track and bolts on. Once you do it once, you'll see.
Here's a video.
https://www.youtube.com/watch?v=fXWLhtj9Xso
1988 Jeep Grand Wagoneer
76k miles
Platinum Silver over Burgundy
In 1987, Road and Track called the Grand Wagoneer "one of the most capable off-roaders going" and "a first-rate off-roader and inclement weather vehicle AMC has honed close to perfection." It also called the interior "truly grand."
Old 03-17-2018, 08:45 PM
nograin's Avatar
nograin nograin is offline
It is a PIA the first time.
You don't have what year your rig is. There was a change somewhere after '85. If you have the older style, you'll need the other parts to switch to the newer style.
http://www.ifsja.org/forums/vb/showthread.php?t=28367
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Old 05-09-2018, 10:21 AM
rayray311's Avatar
Do the rear doors use the same thing? I was about to buy one for my front door and thought I needed one for my back rear passenger side also...but now Im thinking that maybe it doesn't use the same parts....unfortunartely my jeep is in the shop all week getting the lifters replaced so I cant look inside the door to confirm or deny
Old 05-09-2018, 12:52 PM
Tripwire's Avatar
front and rear on passenger are same as well as F-R on the right
Old 05-09-2018, 01:47 PM
rayray311's Avatar
Good to know...thanks man!
Old 05-10-2018, 12:14 PM
rayray311's Avatar
Hey Brother...guy from fsjjeepparts.com told me that they will NOT fit/work on the back doors. So now im confused...below what he said to me.
"Hello
The flex racks will NOT fit the rear doors.
Steve"
Old 05-10-2018, 11:16 PM
SlowGear's Avatar
SlowGear SlowGear is offline
Been a while since I did mine but I believe the difference is pass/driver-side rather than front/rear. All four are the same length but the mounting hardware is reversed for pass/driver side.
Mike
88 Grand Wagoneer
Bone stock - except the missing stuff
new window regulator belt FlashGordon General FSJ Tech 3 03-26-2017 01:51 PM
Difference between power window and manual window glass? Heavy_Metal_Thunder_81 General FSJ Tech 4 04-25-2012 06:14 PM
Help, Power Window Issues 87 FSJ Frank G General FSJ Tech 4 06-22-2011 07:29 AM
Funny Tailgate Window Story tmlint General FSJ Discussion 4 01-17-2011 02:22 PM
Help with reinstalling driver's front window F. Townsend General FSJ Tech 2 10-06-2006 05:06 PM
