Old 03-06-2018, 02:33 PM
Do you guys "seal" your air injection bolts?
I have to re-install the air injection tube on my passenger side manifold.
I have read:
a) some posts where folks have used copper crush washers to seal them but no specifics on size or where they were bought.
b) some posts where folks haven't used anything
c) some posts that use the Team Grand Wagoneer seals
I HATE EXHUAST LEAKS and have had them since I bought my rig. I really want them to go away. so:
1) If you used copper/Aluminum crush washers, where did you get them? I checked my local Home Depot and mom-n-pops hardware store but they had nothing. I checked Oreilly and they are like $3 for 2 of them (I need 6) and they are huge/would look silly.
2) I really don't want to order from TGW. Anyone else sell them?
3) who has installed the your bolts without seals and gone w/o leaks?
4) is there a gasket maker/sauce that I could use? They will only need to hold up for a couple thousand miles...
Old 03-06-2018, 03:36 PM
Don't know what size you need. My bike takes 14mm copper washers in a few places and I buy them on Amazon. Theres about 6 in a package?
Old 03-06-2018, 03:46 PM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
keep in mind i am not much of a mechanic
but once i restored a 69 dodge charger
the person in charge of rebuilding the motor was a GM guy and very young,...
when i got the charger back, i cranked it and
water poured from the exhaust manifold bolts
seems the exhaust manifold bolt(s) on the 383
go into the water jackets,.....
we removed the bolts
dried the block threads and bolt threads and used the high heat Copper RTV silicone sealant.....it has been several years and it is still holding...
for good measure, i also dropped in the stop leak tablets,...
whatever did it, it has worked well...
hope this helps some...
dave in NC
Old 03-06-2018, 07:21 PM
J20 project's Avatar
Pinch it down and braze it
j20
BP Drivetrain...........
775-537-7918
Old 03-06-2018, 07:29 PM
nograin's Avatar
nograin nograin is offline
yes there are or were thin washer like seals.
Lemme look to see if I have pictures. Pretty sure they come with a new tubes, and the old ones are generally OK to reuse.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Old 03-06-2018, 07:46 PM
nograin's Avatar
Yes. This is the driver side so its only 6. Passenger side is 8 seals.
J004 4042
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
Old 03-06-2018, 09:22 PM
TBI allows removal of all useless emissions crap including air injection.
Grade 8 - 9/16” fine thread bolts didn’t/don’t leak 4 me.
Just sayin...
Old 03-07-2018, 01:49 AM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
None of my cars that originally had AIR systems had any kind of sealing washers on them. It seems like they just allowed the surfaces to crush into each other for a seal.
I used copper gaskets for sealing brake line fittings. Most auto parts stores have an assorted bin on them available or at least a catalog listing them by size and part number so they can be ordered.
Eventually the tubes will seal themselves with rust and carbon...
I seriously hate AIR though. More places for exhaust leaks and the pumps seem to die every year or two. I remove it from all my cars, but I understand that your local laws may not allow that.
Old 03-07-2018, 10:55 AM
Originally Posted by nograin
[/url]
OK, copy. Those look like the TGW ones. Maybe I'll just bite the bullet and get them.
Just sayin...
Yep! I already have a set ready! I want to pass my next smog check (May I think) before I install my TBI. That way I'll have 2 years to get it running correctly before the smog Nazi's probe my truck again.
rgr. I hate it, too. Such a complex solution for such a simple problem. I'll be happy to sell all the pieces off of it when it comes off.
Old 03-07-2018, 11:21 AM
nograin's Avatar
Must be other sources.
This company sells in bulk and says they're also used for spark plugs - or maybe that's just the size and used for O2 sensors or something.
https://www.amkproducts.com/bulk3.asp?part=B%2D10369
I've not come across a spark plug that used a crush washer like that, but that doesn't mean anything.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
Old 03-07-2018, 11:38 AM
I think I will order these aluminum crush washers. TGW wanted $19.99 for shipping $8 in washers! hahaha!!!!
Amazon, Earl's Aluminum Crush washers 9/16 ID,
Old 03-07-2018, 11:57 AM
ZackN920's Avatar
ZackN920 ZackN920 is offline
That's ridiculous.
You know, I'm not too sure of this, but I think you can buy these types of washers at a hardware store. Heck, the local menards over here even has them.
...not too rusty anymore
Plenty of patina
The others
1926 Dodge Brothers Business Sedan 212 I4-CRANK START
1987 Lincoln Town Car Signature Series-5.0 AOD (WD)
1987 Dodge Dakota LE 3.9, A999, 3.90 gear (DD)
1994 GMC 'Burban 5.7, 4L60E, NP241, 3.42 gear (DD)
2001 Jeep Cherokee 4.0, AW4, NP231, 3.73 (limbo)
Old 03-07-2018, 12:17 PM
I've checked my local Lowes, Home Depot, and the local Mom-n-pops HW store with no luck. I checked the hardware aisles, plumbing aisles, and ask the workers. There is an OSH up the hill but at this point, I would rather pay the $11 to Amazon to have them show up on my doorstep.
Old 03-07-2018, 12:22 PM
ZackN920's Avatar
huh. How about the auto parts stores?
Plenty of patina
The others
Old 03-07-2018, 12:23 PM
Just use regular bolts, they don’t check funtion just visual.
Inop air system won’t make ya fail smog if your cat is good.
Old 03-07-2018, 12:25 PM
ZackN920's Avatar
i think he's still trying to get rid of exhaust leaks Tony
Plenty of patina
The others
Old 03-07-2018, 12:29 PM
The regular bolts will seal and prevent exhaust leaks unlike the hollow bolts used.
Both of mine had no issue passing smog w/ regular bolts and inop air system, before switching over to EFI and yanking.
Old 03-07-2018, 12:36 PM
Oreilly and Autozone had copper crush washers for oil drain plugs but they were huge and about $3/pair.
That's a good point and didn't really think of it. BUT I think my cat is marginal. It's the original cat and I don't have much confidence in it so I give it all the help I can.
Both! I have to re-install my manifolds for smog (running headers now) so while they (my manifolds) are on my bench, I am fixing all my leaks. these bolts are just some of the leaks. 3 of 4 manifold studs are stripped by the previous owners so both sides leaked there. All 6 gaskets were blown out at the heads. I was missing a bolt that holds the manifolds on. There is a ginormous crack and weld blob on my y-pipe. No joke, this weld blob is the size of my finger and coated in carbon because it STILL leaks. I'll post a pic soon enough. it's almost as epic as Baby-wag's recent oil pan gasket trophy.
Old 03-07-2018, 11:57 PM
coreyw454 coreyw454 is offline
I removed and replaced with stock bolts and it sealed fine.
1985 Grand Wagoneer (project)
1989 Grand Wagoneer (parts for 85/off-road only use)
catalytic converter, air pumps, and a 79 dkmcgowan General FSJ Tech 11 02-27-2015 11:30 AM
Air Injection Plugs KdkGrizz General FSJ Tech 2 09-09-2014 07:27 PM
401 V8 with a One-of-a-kind Mass Air Fuel Injection System sportsidedan Fuel Injection 12 07-21-2009 02:37 PM
air tube bolts fitron74 General FSJ Tech 12 12-05-2003 07:53 AM
Air Injection Manifold - Replace it of Loose it? Nagy General FSJ Tech 5 07-19-2001 05:34 PM
