Old 02-23-2018, 12:39 PM
jeepman1's Avatar
jeepman1 jeepman1 is offline
HEI D'oh
I looked through the archived stuff, I really did.. So, what's the right wire to hook up from a stock 83 harness w/360 to an HEI (Summitt) dizzy? I have a two wire plug on my alt. TIA
: 98 9er
'83 Honcho j10
'12 Liberty Ltd.. wifes
'19 Chaparral H2o Dlx sport 21
Old 02-24-2018, 02:30 PM
J20 project's Avatar
Maybe looking in the wrong place for starters...
I set mine up by finding the approx. 10 ga switched power wire coming from the bulkhead connector area to the old electronic ignition brain on the driver side fenderwell.
Cut that wire away from the brain box, grafted it to 10ga all the way to the hot wire of the new distributer. Having a 3 wire connector on the HEI, one is hot, the other is ground, the other is tach...
I didn't use a summit hei though.. Bought a generic gm style off of amazon. I did however switch over my distributer gear to the new distributer.
J20
BP Drivetrain...........
775-537-7918
Old 02-25-2018, 08:19 AM
charlie500's Avatar
charlie500 charlie500 is offline
I bought a Skip White for 50bucks it was awesome, but i didn't switch the new dizzy gear for the old gear and eventually the new dizzy gear tore up my old cam gear. Expensive lesson.
Old 02-25-2018, 08:22 AM
charlie500's Avatar
Cool comparison between MSD Street Fire and Skip White TSP here.
http://www.hotrodders.com/forum/skip...ed-179906.html
Old 02-26-2018, 04:58 AM
amcdv amcdv is offline
hei
ive always hooked up my power wires for hei and msd boxes to the "I" terminal on the solenoid mounted on the fenderwell.... not the "S" terminal....my 2 cents...amcdv
Old 02-26-2018, 07:59 PM
Alys4x4 Alys4x4 is offline
Noob!
Assuming you are coming from a coil setup...the positive wire on your coil should be hot all times when key is on/cranking. Use that wire for your battery wire on HEI. you can also do a nifty relay setup with 10ga wire.
Old 02-28-2018, 03:35 PM
jeepman1's Avatar
yep had a coil on it previously.
I will take the wire from the old horseshoe positive and hook it to the "batt" on the new dizzy..Thanks
: 98 9er
'83 Honcho j10
Old 02-28-2018, 07:22 PM
[quote]will take the wire from the old horseshoe positive and hook it to the "batt" on the new dizzy..Thanks/QUOTE]
Interesting, the gm style HEI I installed instructions said that it needed to be 10 ga all the way through. Th normal horseshoe type is what, 16 ga?
775-537-7918
Old 02-28-2018, 07:26 PM
One thing to remember is that the coil hot wire is 12 volts at start and 6 volts at run.
775-537-7918
