Old 02-19-2018, 09:53 AM
kgocj5 kgocj5 is offline
14 bolt rear axle swap
I have seen ppl swap in a 14 bolt rearend on cherokees. does anybody know what they took the axle from? how does the passenger side offset effect the swap. does the 14 bolt have the same offset? do you have to cut down the axle and shafts? are the spring perches the same width. is shock mounts same setup. any help would greatly appreciated.
1976 cherokee chief
1979 cj5
1989 4 door cherokee
2004 rubicon wrangler
Old 02-19-2018, 01:38 PM
J20 project's Avatar
Which model of 14 bolt are you thinking of? There are a few to choose from. This lighter duty 6 lug ones from a late model Chev might work out well I have one, I will check the centering and width and let you know what I see.
J20
BP Drivetrain...........
775-537-7918
Old 02-19-2018, 03:05 PM
So the 2000's version 14 bolt I have is about 47ins on the spring perches, about 65/66 ins on the wms to wms, and is perfectly centered.
J20 project
775-537-7918
Wagoneer Rear Seat Swap tenoverthenose General FSJ Tech 4 03-15-2017 10:33 AM
D44 rear axle bearings and seals FSJ Guy General FSJ Tech 1 10-20-2010 06:16 AM
rear axle swap jeeprobb General FSJ Tech 3 04-18-2010 10:45 AM
Ring gear bolt tourque j20brett Off-Road FSJ Tech 24 03-10-2009 09:43 AM
dana 44/ GM 10 bolt, swap axle shafts? Qudawg General FSJ Tech 5 04-20-2005 01:38 PM
