Old 10-22-2013, 06:12 PM
elbastardo elbastardo is offline
Looking for diffarent bed ideas/pics
Im close to picking up my next j truck and I want to do A custom bed. Im looking for some ideas and input
Im thinking something flatbedish with offroad aspects in mind. But my options are open
Thanks
Old 10-22-2013, 07:53 PM
J20 project's Avatar
As the old saying goes, the world is your tomato.
Make what you will...it's all good.
J20
BP Drivetrain...........
775-537-7918
Old 10-23-2013, 04:11 PM
That is very much along the lines I was thinking. There is allot of attention to detail there I would like some stub sides that could be used as storage. The tiedowns on the sides of yours will probably find there way into mine
Old 10-24-2013, 06:29 PM
FSJK FSJK is offline
http://www.ifsja.org/forums/vb/showthread.php?t=129320
Old 10-24-2013, 08:29 PM
REDONE's Avatar
REDONE REDONE is offline
If I recall correctly, those aren't tie downs, those a pop-up stake bed sides! J20P, can we get that pic again, I can't find it!
79 J-10 - The Money Badger!
304/T18/D20/D44s
What's been did:
Holley 4160/Ede' S.P.2.P.
MSD Streetfire based TFI
Custom-hack gauge cluster
Razor swap
2 knob tape deck!
3" homebuilt lift
Half a hillbilly paint job
Old 10-24-2013, 09:06 PM
Actually a combination there. The side rails drop in,,and the tie down rails are permanent on the side.
The really cool parts of the bed are underneath though. I was able to ditch the stock tank(junk and small), built a 36ga unit flush w/ the bottom of the frame, and then slung a semi truck air tank crossways in the back and tie it into a compartment which has my air hose(york onboard), various tools, the slide in ball mount..etc.
The winch works great for pulling elk in,,,sidehilling to the extreme..
The side rails hook together as a atv ramp too.
J20
775-537-7918
Ideas/Pics of Grand Wagoneer Interiors ajminla General FSJ Discussion 2 06-07-2010 08:32 AM
