Old 12-31-2011, 05:54 PM
blazer3664's Avatar
blazer3664 blazer3664 is offline
my goofy winch bumper idea
Forgive the cartoon type colors, I did that when drafting it to make the different pieces stand apart. Keeping the outer pieces pretty minimal to keep weight down some. The center bar will be 2" heavy wall (.250 probably) and come back far enough on the frame to be part of the mount. The outers will be smaller, 1 1/4 probably. The plate will be a combination of 1/4" and 3/16" with the winch plate 3/8" or 1/2".
The pink part is the basic front frame measurements.
Definitely NOT a final draft or anything, but it should be fairly close to what (shape) my bumper will look like when I get to it.
front view. AMC on the left, JEEP on the right brace, and pretty sure you can read the middle. The brush guard will be bent to mach the hood lines, they are a little off here, but you get the idea.
My quickie boxy (ugly) front clip, and from slightly above to give an idea how tight it sits, and the angles of the bars.
And the grill will be changed out so the winch can sit back farther, but not as much as it looks in that pic. I didnt take the time to angle the grill piece back in my sketch. I will leave about 3-4" between the radiator and the winch, but thats it.
So, any suggested changes for when I do a final draft?
Jim
modified flares, removable top, OBA w/200psi tank,
LQ4, 4L80e,NWF doubler w/upside down 203
SOA w/ D44s F+R for now
H1 wheels+tires (cut), hydroboost brakes
custom shackle flip
W/F150 springs
-----Coming Soon-----
snorkels,
OX'd D60/14B-FF
Old 12-31-2011, 06:03 PM
JeepsAndGuns's Avatar
Looks pretty good to me. Would be real interested in seeing what it would look like in real life.
Old 12-31-2011, 07:08 PM
elbastardo elbastardo is offline
Wierd, im on to A winch bumper idea aswell. My idea is very similar to yours So either im as smart as you Or your as dum az mi
Im interested in what you come up with though. The part im most interested in is the bumper portions, the lines look really smooth When do you plan on building this?
Old 12-31-2011, 07:44 PM
p@55w0rd's Avatar
p@55w0rd p@55w0rd is offline
Love it! What would you charge to build?
Project: 1979 Wagoneer 360, Turbo 400, Q-Track, and Dana 44's
Lovingly refereed to as the "The Wagon"...
Daily Driver: 2008 Jeep Commander Rocky Mountain Edition 4.7L, Q-Trac II
http://i285.photobucket.com/albums/ll58/jeepxk/DSC08388.jpg
Old 12-31-2011, 08:13 PM
novacayne75's Avatar
novacayne75 novacayne75 is offline
i dont see anything goofy about it.
actually it looks like my bumper
78 j-truggy d60/14b,42's,tbi.
97 zj long armed and locked on 35's
03 quad cab 3500 ctd tow pig.
Old 12-31-2011, 10:07 PM
blazer3664's Avatar
If my overtime at work kicks back in fast and holds, maybe next fall.
I have to get the rest of my drive line together first, (doubler kit is on the way) so I can drive it to places to work on it. Also need to get a tube bender and such.
Actually, thought had crossed my mind about seeing if anyone would be interested in a partial kit. Something with just the pre-bent tubes and main braces, and a cut list/blueprint for the plate steel. Its mostly flat pieces other than the 2 main tube mount/braces (purple). Plus that would allow people to customize a bit as well.
I always keep notes when I build something like this, so I should be able to make another fairly easy afterwords.
We'll just have to see when I get that far.
If I do that, it will be around this time next year though (funds permitting). I would have to see what the tubing runs before figuring a price.
Glad you guys like it.
Oh, forgot to ask...............
I have two options on the AMC/JEEP/CHEROKEE script....
1) cut them all the way through, I doubt it would weaken it enough to worry about.
2) only half way through, and paint the lettering a contrasting color.
I guess there is a third option
3) all the way on the tops, and half on the CHEROKEE
Opinions???
Jim
custom shackle flip
W/F150 springs
snorkels,
OX'd D60/14B-FF
Old 12-31-2011, 10:27 PM
KJ Ryu's Avatar
KJ Ryu KJ Ryu is offline
Cut the letters from another plate and weld to it, in my opinion, would look best. And no worries of structural loss.
Ron
2005 KJ, Hit-n-Run, 2am 6-17-2012, Totaled.
1977 J10, 2v304, T18, D20, 37x14s, SOA & SF on tons, still ugly Occasional driving!
1978 SJ Wagoneer, 360, QT, 33x12.5s, lift by Sawzall NOT Running
1977 J10 4v401, TH400, BW1339, mostly stock DD
Originally Posted by Mars
One man's trans leak is another's penetrating oil
Old 12-31-2011, 10:30 PM
blazer3664's Avatar
Kinda funny you mentioned that after I realized what bumper you are talking about. Had to go look it up. You are right, and I am busted .
I saved that pic (and many others) in my ideas file I used to come up with my design. Thats where I got the idea for the bars following the hood line. Hope you dont mind my following your lead.
Jim
custom shackle flip
W/F150 springs
snorkels,
OX'd D60/14B-FF
Old 01-01-2012, 04:38 PM
83 BEAST's Avatar
83 BEAST 83 BEAST is offline
Looks great. Can't wait to see all the build pics.
The Beast: 1983 jeep j-10, 258ci, t-5 trans, np-208 t-case, d44(f) amc20(r), stock gears, 32" tires, (just passed emissions as of 12-16-11 )
Old 01-01-2012, 07:29 PM
Jim
use it pm me if you need any measurement's or material suggestions!
Old 01-02-2012, 09:20 AM
The hoop design looks a lot like this bumper.
I also found these pictures on my computer I saved. I do not know who it is, but I saved the pics cause I kinda liked the bumper. The tube part is a little diffrent.
Also saved this pic of a baby jeep. The tubes on it look close to like your drawing.
Old 01-02-2012, 10:30 AM
johnwaynejeep2
Posts: n/a
I really like the design. It looks beefy like a stinger but without the 3ft of steel cliff hanging off the front.
Great concept, good luck with it.
The names on the front, I would cut the AMC and JEEP all the way through and then weld on raised lettering for the Cherokee emblem.
Old 01-02-2012, 08:20 PM
Wagn Man's Avatar
Wagn Man Wagn Man is offline
I so want one!
78 Chero NT..... nickname "Crash"
84 GW 401, Rhino Grille
03 Chevy Silverado 2500HD My DD/Tow Rig
Old 01-08-2012, 07:08 PM
TINMAN93's Avatar
TINMAN93 TINMAN93 is offline
Hoopster
Those are some good looking hoops.
I've been thinking about upgrading mine to round tubing, and these are just the look I was searching for.
Tinman
- '91 SJ: BoB'd 13", Lift Hatch, Sliders, Tackbar & more DIM toys.
- And, He who dies with the most toys, still Dies!
Old 01-09-2012, 11:45 AM
orangecherokee's Avatar
I like the Cherokee name on the front but not the AMC or Jeep. It looks too busy for my tastes. The design looks solid though.
Warn classic winch bumper ?s jepj2000 General FSJ Tech 6 01-08-2012 02:33 PM
Winch Bumper / Towbar, Frame Strap Artisan General FSJ Tech 38 12-31-2010 05:45 PM
Winch Bumper modification etjeep Off-Road FSJ Tech 12 08-03-2007 01:52 PM
bumper and winch pics youngjeeper Off-Road FSJ Tech 5 04-07-2004 12:32 AM
