View Poll Results: what lift combo should i run?
2" springs, SOA, 2" BL (10") and run 38's. go big or go home.
60 |
32.43% |
2" springs, SOA, no BL (8") and run 36's. drop the motor/trans and give the HD44 a chance to live.
30 |
16.22% |
stock springs, SOA, 2" BL (8") and run 36's. stock springs are soft, but i probably won't roll it.
39 |
21.08% |
stock springs, SOA no BL (6") and run 35's. keep it low so i don't get nose bleeds.
39 |
21.08% |
4" springs SUA, 2" BL (6") and run 35's. i'm kidding. don't vote for this.
17 |
9.19% |
06-01-2012, 07:59 AM
I play with rocks
Kaiser - 1981 J20 115" WB - 5.3l/4l60E/np241c/3-link hp60 spooled/Leafs 14-bolt detroit/5.13's/40's
Build Thread
Fight Crime...Shoot Back.
ΜΟΛΩΝ ΛΑΒΕ
06-01-2012, 08:41 AM
Originally Posted by j20brett
I play with rocks
Barnwell has rocks? I thought it was just red dirt?
06-03-2012, 06:57 PM
what rock?
Awesome picture is awesome.
There are no rocks in New Jersey
1990 GW:
Mopar 440/727/229/D44F&R
10:1, XE250H, DIY TBI. 4.10 locked f/r, SOA/SF, high steer, all the other fancy goodies. Check out my build on FSJNETWORK.
06-04-2012, 10:45 AM
you only have to travel about an hour and a half for good wheeling.
06-13-2012, 11:18 AM
Canada is further away than that! :P
Just sayin!
06-20-2012, 09:39 PM
I realize it's far to late to vote. My candidate was never a contender anyhow. I'm one of those who consider lifts of any sort to be a sometimes-necessary evil. My plans for my own Cherokee involve 38-42 inch tires and (hopefully) no lift. Jeep's show truck, "Lower Forty", was my inspiration for the idea.
I appreciate that many think cutting the fenders ruins the lines of the truck. But I think it's only ugly when it is done poorly. It takes just a little more work and planning to "stretch" a wheelwell without altering the look of the truck. Drag racers have been doing it with their cars for decades; http://forums.h-body.org/viewtopic.php?f=15&t=25910 And the square lines of the WT flares should make it a whole lot easier.
06-23-2012, 05:25 PM
6" springs with SOA and SF 3" Body lift. run 49's. go big or go home
'79 J10/360/T400/Quadratrac/Bone Stock
'78 J20/360/T400/Part time conversion QuadraTrac/6" lift with 35's
06-25-2012, 06:22 PM
Even if you cut all the way up to the hood, you are going to need lift to be able to have any room to flex. M715's fit 37's stock, but its a tight fit. And there have been people that do M715 style fenders in back, and it can look good if done well. But you will still need some lift to have any articulation.
On the Lower Fourty Concept, they raised the fenders several inches. And it should be noted you can fit 35's on a JK with no lift (granted its tight). On a wagoneer, you can fit 31's, and its very tight.
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
07-01-2012, 07:20 PM
When your from south Texas Barnwell seems like a big freaking rock.....I agree with you, its just a big pile of packed down red dirt.
1994 YJ
Amc 360
TF727
Stak 3 speed
44" Pitbull Rockers on Trailworthy H1's
Rockwells
76' Wagoneer
401....new project
Tow Rig Daily Driver// 2007 6.7 CTD Dually
07-01-2012, 07:59 PM
I had to put down that I would go with the SOA and a 2" BL. Enough hiegth to do what you want and not so much to be ungainly. Plus, you retain that stock spring rate and that is pretty sweet. Same route I am going with mine.
'75 Wagoneer, bone stock, about to be a whole garage of parts. Tear down starts 3 March, 2012,
see how long it takes to put it back together....
'91 XJ, 3 in Rough Country lift, 33's, Rattle can paint job, roof rack and cheapo off road lights. Diffs and winch next
09-19-2012, 05:26 PM
1984 GW T18/205
Originally Posted by TheDude
Garrett called me maybe 30 minutes ago with a blown tire, but knowing PBR is on the line not much can stop us
11-14-2013, 06:09 PM
Is Al still around? Looks like Ill be dragging my own cherokee home next week
