Old 02-22-2012, 10:29 PM
AKjeeper AKjeeper is offline
weird/dumb question
SO I was wondering................I have a set of 4" lift springs that came off my half ton Chevy blazer.......I know my front wagoneer springs are 46" long.........my 4" chevy lift springs are 46" long............would the chevy springs work on the wagoneer? I know the waggy springs are 22.5x24.5 and my chevys are 23.5x23.5. The only difference I can see is the offset between the center pins being unequal on the wagoneer.
Old 02-22-2012, 10:30 PM
2nd question would be IF they even fit would they provide any lift?
Old 02-22-2012, 10:44 PM
Suddendeath's Avatar
Suddendeath Suddendeath is offline
I'm not the greatest person to answer this, but I'll give it a whack.
If the springs are the same length, eye to eye, and they're the same width, and the only difference is the center pin offset, it would work but it would move your axle about .5" forward if my math is correct.
Can't tell you if they'll give you any lift or not. Compare the weights of the two trucks. It very well may end up riding horrible, even if it does fit.
1990 GW:
Mopar 440/727/229/D44F&R
10:1, XE250H, DIY TBI. 4.10 locked f/r, SOA/SF, high steer, all the other fancy goodies. Check out my build on FSJNETWORK.
Old 02-22-2012, 10:57 PM
Thats what I was thinking, same length and same width so why wouldnt they? If anything it might push the front axle forward a tad bit which I could deal with but if it pushed them rearward then it would be a problem. As far as spring rate goes Im thinking that a half ton blazer and a wagoneer both with V8's would be close in weight.
Old 02-22-2012, 11:02 PM
looking at a diagram I think it would push the axle forward a tad bit which wouldnt be so bad, but now the question is will it provide ANY lift?
Old 02-23-2012, 12:59 AM
Carl78Cher's Avatar
Carl78Cher Carl78Cher is offline
If you do a search on here, I read where someone is using 6" Chevy front springs SUA and he got 3" of lift that way. So you would probably wind up with approx. 8-9" of lift spring over on Chevy 4" springs.
72 J2000 - under construction
Old 02-23-2012, 11:15 AM
did some extensive searching and I discovered that 4" chevy lift springs will work and would net approx 2" of lift if kept sprung under. I might use them because my waggy springs are slowly bending into a S shape
Until I do my full width swap Im gonna go with 2" from the chev springs, a 1" shackle extension in the front for a total of 3" suspension and then cap it off with a 2" Body lift for a total of 5" and 33's
Old 02-23-2012, 06:25 PM
elbastardo elbastardo is offline
Do itttt
Old 02-24-2012, 03:23 PM
CutterN55's Avatar
CutterN55 CutterN55 is offline
what are you doing in the back? I didn't see you mention anything about rear springs...
ROMANS 12:1-2
Military guys- Check out www.MilitaryJeepers.com
'89 GW deceased
Ford 4spd swap Np435/205
Lifted/stretched on 36's/4.10 thick gears/spooled rear
'86 CJ-7 Renegade, Restored, original steel.
new Built TBI 258/Np435/D300 twin-sticks/Waggy D44's
37" Super Swampers and lots of goodies!
Old 02-24-2012, 08:01 PM
Rear springs are easy to setup after the front sets the ride height.
Do itt
Another A/C Question: York or Sanden The PIG Smith General FSJ Tech 27 07-03-2018 04:29 PM
1 PS question, 1 eletrical question SamW General FSJ Tech 2 01-15-2011 12:31 PM
Quick 85 Grand Wagoneer Question WagoneerMan General FSJ Tech 3 01-31-2010 11:06 PM
2100 Question Deacon General FSJ Tech 15 03-14-2007 01:12 PM
