Old 05-05-2018, 09:39 AM
spyderkeeper's Avatar
spyderkeeper spyderkeeper is offline
More TBI log help
Hi, I'm still trying to figure out my rough running/stalling TBI. I rewired the computer and some burnt wires under the hood. It looks like my voltage is stable again. Could anyone take a look at the logs and give me some pointers?
https://drive.google.com/open?id=19e...iZzpPJiqGeaaz9
https://drive.google.com/open?id=1XO...qBaSMNDP57ty9-
https://drive.google.com/open?id=1h6...II3XRUP809kGPS
Marvin -- '87 Grand WAGONEER, Big Lift, Big Tire
Bob -- '89 GW, No lift, No tires
There's a reason some suspension bolts have MF on them.
Old 05-05-2018, 10:02 AM
From what I see, the TPS isn't adjusted correctly.
It's dropping to .2v which is too low.
If you didn't perform the initial setup, you need to do this.
http://www.binderplanet.com/forums/i...3/#post-345737
And common sense dictates verify no vacuum leaks, and fuel pressure is good.
Lots of knock counts, are you using a knock sensor?
Old 05-05-2018, 11:49 AM
I bought the Jeep with the setup but the distributor was changed by the mechanic, so I will try resetting everything from scratch. I'm not sure what the knock sensor is picking up because it doesn't sound like that.
Old 05-05-2018, 12:04 PM
Hmm, the TPS is showing .53 at idle now.
Old 05-05-2018, 01:43 PM
Hmm, well actually this does not look good.
Compression:
8 7-120
6 - 120 5-89
4 - 120 3-100
2 - 120 1-100
Maybe I'm getting all I'm going to get.
Old 05-05-2018, 01:56 PM
yeah not good...
do a leakdown test and see what exactly is going on.
or just pull head since all low ones are on same side?
Old 05-05-2018, 02:29 PM
What would cause low compression all on one side, cam shaft issue?
Originally Posted by babywag
yeah not good...
Old 05-05-2018, 05:28 PM
best case scenario bad head gasket
worse case burned exhaust valves
worst case would be broken ring lands/pistons
If it was cam you probably be hearing noise.
Old 05-08-2018, 06:08 AM
TexasJ10's Avatar
TexasJ10 TexasJ10 is offline
Your mechanic locked up the replacement distributor, right?
Couple of questions on my Howell TBI Blake Fuel Injection 2 03-26-2012 03:17 PM
TBI throttle cable?? JeepsAndGuns General FSJ Discussion 17 02-17-2011 06:06 PM
D.I.Y Throttle body injection write up (With pics!!!!) and this is no hoax Wagoneerlover Engine 28 06-25-2007 12:43 PM
D.I.Y Throttle body injection write up (With pics!!!!) and this is no haox Wagoneerlover Fuel Injection 28 06-25-2007 12:43 PM
Engine R & R write up SFFSJ General FSJ Tech 0 04-16-2003 05:03 AM
