Old 01-09-2019, 08:50 AM
Zorm's Avatar
Zorm Zorm is offline
th400 transfer case options
Picked up a 78 Cherokee Chief with the th400 and quadratrac, would there be a Chevy transfer case that would mate to the jeep th400?
thanks
83 Cherokee 4dr WT(axles) 4" lift, 351w, nv3550, NP208, installing soon
65 Corvair Corsa Convertible, 4 speed, 140 quad carb engine
71 F-250 Camper Special (in rewire stage)
HE guides my path, forgives me when I stray and lights my life.
Old 01-09-2019, 09:04 AM
Cecil14's Avatar
Cecil14 Cecil14 is offline
Nothing without an adapter and different output shaft. The QT is a majestic unicorn, unique among the rest of the beasts.
aa
Old 01-09-2019, 11:26 AM
Yes, he is correct, I am working on this now on a project I have, amc turbo 400 and a dodge 241 transfer case, p.s. drop, found an adapter that will work that is inexpensive but requires the trans to be rebuilt with a chevy output. I do like the quardratrac a lot but wanted to try something different.
Old 01-09-2019, 12:02 PM
AMC ran the Jeep D20 behind the th400 before the Qt came along. The JeepD20 also required a factory adapter and a different output shaft on the trans. If you go D20 I suggest using Novaks alum adapter. Much better design than the factory cast iron version. Also if you score a Jeep D20 make sure it came from behind a th400. D20's use different bull gears for manual and AT's. Run the p/n on the bull gear through Novaks web site to know for sure. Mismatched they're pretty close and will still fit together but the tooth pitch is different so wear/longevity is compromised.
Old 01-09-2019, 01:19 PM
Zorm's Avatar
ok, thanks gents
Old 01-09-2019, 02:37 PM
Crankyolman's Avatar
Now maybe I'm being dumb here so correct me if I'm wrong but didn't Chevrolet at some point use the TH400 in some of their 4wd setups? I know it would require changing the output shaft and adapter but you have to do that anyway if you change the TC and aren't all TH400 essentially the same internally (only minor differences) regardless of the bellhousing bolt pattern?
'72 J4500
Old 01-09-2019, 03:07 PM
Cecil14's Avatar
Yup, you can grab any standard GM TH400 will work as a donor, the guts are all the same. You can swap the tail shaft and factory adapter to the AMC case.
aa
Old 01-09-2019, 08:37 PM
aa
That's what I thought... so the actual answer to the OPs question
is yes provided you get the transfer case and donor trans out of a GM truck and swap the tail shaft.
While that may not be the easiest or cheapest solution it would seem there are several options as far as possible tranfer case options. Speaking of expense, the Novak adapters alone run over $500 so that's not exactly a "cheap" option.
That said, Novak Has adapters for many different transfer cases giving even more options. https://www.novak-adapt.com/catalog/...case/th400-to/
'72 J4500
Old 01-09-2019, 08:51 PM
Cecil14's Avatar
Yes, adapter and tail shaft. It's a factory adapter, but still an adapter nonetheless.
aa
Old 01-10-2019, 09:17 AM
cu4whln's Avatar
cu4whln cu4whln is offline
Hmm, is it the Q-trac reliability that has you concerned?
Why not install a "Part Time" kit in it? Basically makes it into a normal part time unit.
That way no fancy adaptors or propshaft changes are required. I have this set up in my 77 Chief.
Just a thought . .
1977 "401" 'Da Chief
1979 Chero: "Madness" [Sold]
2001 XJ : Driver - 2016 JK 2 door
Round 2- LT Swap: 'Da Chief:
"Madness" build here:
Old 01-10-2019, 10:07 AM
Just a thought . .
I agree. it it ain't broke, don't fix it. The part time kits are a lot less $$ than swapping a case. Parts for QTs are getting expensive but they are out there (just check ebay).
Also, if your case is part time, you eliminate a lot of the (expensive) wearable items. When you swap a case expect to have issues like Speedo hookup, new/modified driveshafts, possibly a new cross member, possibly re-routing exhaust, and you have to figure out a shifter, too.
Old 01-10-2019, 10:39 AM
Cecil14's Avatar
The only real issue with the P/T QTs is still the chain. Even with a part time conversion, both outputs are driven by the chain (front obviously only in 4wd). This still leads to chain stretch and replacement, though certainly less frequently than without the P/T kit.
aa
Transfer case options Cannaert General FSJ Tech 5 03-20-2010 12:29 PM
transfer case shifter in J-20 soxcloud General FSJ Tech 5 04-21-2008 10:53 AM
QT dying - Transfer case options? Grimjaw General FSJ Tech 7 03-08-2006 01:36 PM
Transfer Case cracked driving to work today vistalite General FSJ Tech 5 04-21-2005 09:54 AM
Tranny or Transfer Case Bad???-long Marshmountain General FSJ Tech 4 09-23-2003 03:30 AM
