Old 06-08-2018, 07:39 AM
cu4whln's Avatar
cu4whln cu4whln is offline
Rear truck Flair on a Chief ? Will it work?
So - getting back on track with the Chief.. the rear flairs need some repair.. and making those parts is going to be a bear.
I have access to a ruined truck bed that has flairs with no rust.. can the lower sections be removed and used to replace/patch the rust on my Chief?
Are the profiles the same? Only need the lower 14" or so.. front and back.
strangely, the rest of the Chief is rock solid...
Experts ?
1977 "401" 'Da Chief
1979 Chero: "Madness"
2001 XJ : Driver 1998 XJ 2 door
"Madness" build here:
Old 06-08-2018, 07:51 AM
I think theyre the same. The Truck flares are single layer while the wagon ones are double but I think theyre the same
Old 06-08-2018, 07:56 AM
cu4whln's Avatar
Great! That's what I think too...
I can fab some type of inner section to close it out, but that compound outer curve part, UGH!
Old 06-08-2018, 08:19 AM
Thomas792's Avatar
Thomas792 Thomas792 is offline
I have a link saved on another computer of mine. Give me some time to find it. It was a blue Cherokee that someone used J10/20 flares on. There was a bit of work to be done as the J10/20 profile is different, especially in the back.
1974 J10 (401, Th400, Q-Trac, D44s, 28" tires)
Mrs Tickity - 1988 GW (360, 727, 229, D44s, 32" tires)
Old 06-08-2018, 08:25 AM
Thomas792's Avatar
I hope cross posting from the rebel site is permissible.
http://www.fsjnetwork.com/forum/viewtopic.php?t=2737
See the 5th post down.
BTW, if you have any info on how to WT fender a GW, it would be appreciated.
Old 06-08-2018, 09:11 AM
Thomas792's Avatar
And the full build thread from the rebel site.
http://www.fsjnetwork.com/forum/viewtopic.php?t=2803
Gives me inspiration for my GW.
Old 06-08-2018, 10:47 AM
8man's Avatar
8man 8man is offline
Please post pics of how you get the truck flairs on the Cherokee.
Old 06-08-2018, 10:55 AM
The rear contour is slightly different but modifiable.
-Jonny B.
D20 - Twin Stick'd
F D44 - 3.54, Open
R D44 - 3.54, Lock'd
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 06-10-2018, 07:49 PM
cu4whln's Avatar
This is great news! Thanks for the replies guys..
As I proceed, I will try to get some pics from the body shop.
This is beyond my skillset !
Old 06-11-2018, 09:17 AM
I did a "full flair" swap on both sides of that red Cherokee under the car port that you had your eye on Jim.
Others have said that there is some slight difference but I did not notice that, mine seemed to fit perfectly. I did notice a slight difference between the right and left sides, perhaps this is where the discrepancy that others have found is.
If you study the configuration of the Cherokee flair you will see that it is trimmed just inboard of the body side. I have come to believe that Jeep used truck flairs the build the Wide Track body, they probably trimmed off the unwanted portion with a power shear. I simply can't believe they spent the money on new tooling.
Resistance is not futile yet.
Old 06-11-2018, 08:23 PM
cu4whln's Avatar
Hi Dan! Long time no see! Hope all is well with you..
I also think AMC would not have retooled a new flair..
Interesting... I will have to hire somebody to do this swap, but will watch intently and try to document what happens.
I am sure I'll need some parts soon.. will be in touch! Jim
Old 06-15-2018, 10:57 AM
I thought I read a thread here once where someone did this and they said the rear side of the flare on a J truck was longer and had to be shortened to fit the Cherokee panel...
Found it:
http://www.ifsja.org/forums/vb/showp...9&postcount=63
Old 06-15-2018, 12:09 PM
Thomas792's Avatar
He also posted the same build on the FSJNetwork site. See post #5 and #6 of this thread for the pictures there too.
Old 06-16-2018, 07:30 AM
Thanks Rang! I thought it was Strode's build I was thinking about but couldn't find anything. Now I know why lol
-Jonny B.
D20 - Twin Stick'd
F D44 - 3.54, Open
Old 06-20-2018, 10:19 AM
cu4whln's Avatar
Thanks so much for the info guys - MUCH appreciated !
OK - getting lined up to acquire a good set of flairs off a rusted bed. Excited!
Now, I made contact with not 1, but 2 retired AMC Jeep engineers .. [ I know them anyway ] and they BOTH confirmed and think the flair for the trucks was indeed used for the wide track bodies. they both worked in Jeep engineering btw....
The minor discrepancy is one guy said it was the same, the other said there was a secondary trim to remove some material.
Either way, I will be using these parts as "patch" pcs to fix my lower flairs. I will leave it up to the body shop, but I think only the lower 15" or so of these need to be sectioned into the repair area. The rest of the body is fine ... mostly. LOL
This will be so much easier than having the complex curves and shapes fabricated from scratch ..
I WISH somebody would tool metal lower wide track repair parts !
Will be some time until I get the parts and update this info ...
Old 06-21-2018, 07:22 AM
"the rebel site"
That is funny poo-poo right there I tell ya.
My J-4500 Crankyolman FSJ-PRIS 241 01-18-2020 09:03 AM
Anyone ever seen a factory rear J truck bumper? <79 Adam_Tinkerer General FSJ Discussion 16 04-06-2011 05:46 PM
77 Chief rear disc conversion Qs supergeess General FSJ Tech 0 03-31-2011 10:10 AM
J Truck rear slider removal. Long&Low General FSJ Tech 4 11-20-2008 08:41 PM
Need pics of rear J truck bumpers gte901m General FSJ Discussion 5 09-09-2008 09:54 PM
