Old 08-21-2006, 04:14 PM
j20brett's Avatar
j20brett j20brett is offline
360 AMC
Jeep D60 rear disc conversion?
anyone ever done this and if so what parts were used? i found some kits on ebay for ford and dodge, but u didnt know if they would fit or not. anybody?
Build Thread
Fight Crime...Shoot Back.
ΜΟΛΩΝ ΛΑΒΕ
Old 08-21-2006, 04:34 PM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
J10Mike has a write up at: http://12.29.16.230/mmimages/index.htm
Old 08-21-2006, 05:27 PM
HOOT's Avatar
HOOT HOOT is offline
I just ordered my kit from the guy who made J10Mikes. Real nice fella called me back about an hour after I sent an email requesting info. Put it on plastic and hope to see it this weekend.
It is a full kit minus the Ebrake cables. He has a contact for getting them made as well. Appearantly there is a couple of different variations on the J20 out there and they need to be done per vehicle to assure correct fit.
If mike doesn't send you the info I will send you his name and contact when I get home from work in the morning.
Tom Gibson
1980 J20 Utility bed truck. Factory cab and chassis truck. Many new mods for it but it will look all stock.
1985 J10 nothing special just a nice clean stock truck.
2017 Challenger. Very jealous of the Jeeps.
Old 08-21-2006, 07:55 PM
j20brett's Avatar
360 AMC
thanks for all the info guys! looks like it would be worth doing...eventually lol
Build Thread
ΜΟΛΩΝ ΛΑΒΕ
Old 08-21-2006, 08:05 PM
Herk's Avatar
Herk Herk is offline
Hmmmm, my rear 12" drums are getting pretty used up. What calipers does this setup use? Those look like a common pin-type Delco. 5 on 5 1/2 rotors? Anybody running it?
Old 08-22-2006, 08:07 AM
J10Mike's Avatar
J10Mike J10Mike is offline
Delightfully Incompetent
Thanks Elliot. It's hard to believe the D60 was that clean.
The calipers are are for a 77 Eldorado. But, if you don't need a parking brake, standard FSJ or Chevy truck front calipers fit the brackets.
I have been very satisfied with the results since doing the conversion.
Tom, I never did look for a cable for the parking brake. If you come up with a company name, please forward that to me via PM or email.
www.j10mike.com
Old 08-22-2006, 08:25 AM
j20brett's Avatar
360 AMC
so did the brackets and bolts come in a kit, or just stuff pieced together?
Build Thread
ΜΟΛΩΝ ΛΑΒΕ
Old 08-22-2006, 08:40 AM
jeepsr4ever's Avatar
www.Bulltear.com Chief
I did up a J20 rear with ford brackets and spaced them out before carefully tacking and welding them in. I used common chevy calipers instead of el dorado as the el dorado calipers need constant adjustment.
AMC/Jeep Forum
Old 08-22-2006, 08:44 AM
J10Mike's Avatar
Yes, everything (brackets, bracket bolts, rotors, calipers, pads, caliper bolts, spacers, flexlines, and hub seals) I needed came in the kit with the exception of the new brake hardline that is fastened to the axle. The hard line can be found at any auto parts store for under 5 bucks. A tubing flare tool would also be useful.
www.j10mike.com
Old 08-22-2006, 09:04 AM
waggin'ear waggin'ear is offline
Mike,
Do you have contact info for the guy who made your kits? I searched the site a little, but did not find it easily.
adam
Gotta a lot of junk
" I may not be good, but at least I'm slow"
Old 08-22-2006, 09:17 AM
J10Mike's Avatar
Originally Posted by waggin'ear
Mike,
Sending you a PM with his contact info.
www.j10mike.com
Rear disc brake conversion Al Evitts General FSJ Tech 27 12-04-2006 09:39 PM
Jeep D60 disk brake conversion write up. J10Mike General FSJ Tech 10 10-25-2005 04:06 AM
need new rear end -- would like move to disc brakes marmoset General FSJ Tech 7 08-22-2003 02:06 PM
Rear Disc Brake Conversion - How Do I Do It Jeff Wood General FSJ Tech 7 02-27-2002 03:54 AM
