Old 09-17-2003, 12:43 AM
The Donzi The Donzi is offline
Anybody got a list of parts #'s or models of rotor/caliper sets that will work?? I am trying to get a 3/4 ton chevy backing plate but they are scarce so I will probably make my own, any suggestions???
1979 Cherokee Chief <br />360,400,1339,44,14ff,SOA,<br />Hydro assist,44044\'s, 63\" chevy rears, Dual electric fans, 35\"SX\'s on hummer rims Rhino lined interior, f/r reciever hitches, Warn 9000i<br />Edelbrock intake, truck avenger<br />Engle cam, chopped, caged
Old 09-17-2003, 01:13 AM
jeepsr4ever's Avatar
www.Bulltear.com Chief
Oh man your going to love the brakes now
ok heres what i use....thanks pirate in advance
rotors 77K20 chevy truck
calipers 77K20 chevy truck
and you make a plate to weld to the housing and hold the caliper
check out por4x4 for more info on this, they got some GREAT tech about this swap
AMC/Jeep Forum
Old 09-17-2003, 01:27 PM
JeepsAndGuns's Avatar
just check ebay for the caliper mounts, there on there all the time.
Old 09-20-2003, 08:12 AM
netbear netbear is offline
How are you setting up a parking brake or are
you just running without one?
Any way you could post some good pic of
your rear disk brakes installed?
netbear
Old 09-20-2003, 09:33 AM
I have a Dana 60 out of a late 70's J-20 on my Cherokee.
What is the upgrade path to replace the rear drums with Disk Brakes.
I have the 8-lug on 6 1/2" center pattern.
Old 09-22-2003, 02:15 AM
Here is what I am going to use, don't know if it is 100% bolt up yet but I'll let you know.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2431927473
Old 09-22-2003, 05:26 AM
nxcj nxcj is offline
I use bolt on brackets similar to those in the ebay ad and they work perfectly. Curious though; I didn't need the spacers. On a 14 bolt you need 3/4" spacers and on a 60 you shouldn't need them.
\'86 Wag - Sold! Currently \"Wag-less\"<br />\'94 Baby Jeep w/ stuff<br /><a href=\"http://www.ci4wi.org\" target=\"_blank\">www.ci4wi.org</a><br /><a href=\"http://www.miobi.org\" target=\"_blank\">www.miobi.org</a>
