Old 05-07-2013, 10:41 AM
the original Honcho's Avatar
How do 3 belts break at the same time?
All My Belts Broke As I Was Turning Into Work This Morning Except The Power Steering Pump To Smog Pump Belt. According To The McParts Sites, There Are Different Belts For The Different Amperage Alternators.
How Can I Tell Which Alternator I Have?
1980 Jeep J-20
1979 Jeep J-10 Honcho
1991 Jeep Grand Wagoneer
Unknown
1968 Plymouth Satellite
1978 Camaro- back in action
Old 05-07-2013, 10:44 AM
you don't have the oddball alt. (84 amp). wouldn't matter if you did,slight length change.
all 3 broke? locked up water pump?
Old 05-07-2013, 11:00 AM
Water Pump Spins Freely, I Can Hear It Pumping The Water. I Heard The Snap Of The Belt As I Was Turnin Into The Parking Lot And Thought The Engine Died Because No Power Steering, But It.Was Running Fine.
Coincidence?
1980 Jeep J-20
Unknown
Old 05-07-2013, 11:03 AM
serehill serehill is offline
Gone,Never Forgotten.
easy
All the same age one broke & took the others out tangling itself in the pulley & mechanism. Could have happened.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 05-07-2013, 11:19 AM
yah,that can happen too.
Old 05-07-2013, 12:10 PM
Yeah
It died from belt binding if the center belt comes off it will take the other 2 out. They wrap around the pulley & kill the engine.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 05-07-2013, 01:24 PM
I Think That's What Probably Happened! Looks Like The Ribs On One Belt Are Sheared Off, And One Was Wrapped Around The WaterPump
1980 Jeep J-20
Unknown
Old 05-07-2013, 02:25 PM
ClovisMan's Avatar
ClovisMan ClovisMan is offline
Time exploding belts. Just like those messages Inspector Gadget used to get.
1988 Grand Wagoneer currently in pieces across the shop.
Old 05-07-2013, 04:47 PM
rockrollin's Avatar
rockrollin rockrollin is offline
Warranty ran out
I've had one bad belt take out the other two also
OI!IIII!IO "I like fun" Eddie Ott
Clawed 90 GW
Slightly off stock
Old 05-07-2013, 04:51 PM
Been there
One belt
carnage
3 belts
transmission lines
radiator hose
radiator
fan
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 05-07-2013, 06:43 PM
The PIG Smith's Avatar
King Browless
Fan Belt Mites.
They eat the fan belt, weakening the belts, causing them to break.
Fan Belt Mites are very difficult to get rid of.
I think Ristow has a home brew remedy that makes these Fan Belt Mites sick, but does not kill them, for Ristow is a true Humanitarian
Bryan Smith
Originally Posted by Jayrodoh
Originally Posted by Lindel
Old 05-07-2013, 10:09 PM
Neighbor's cat took out mine last year
Old 05-08-2013, 04:32 PM
LOL! i woulda responded sooner.....but i needed a place to set my condor egg omelet down.
Old 05-08-2013, 08:30 PM
pcoplin's Avatar
pcoplin pcoplin is offline
Those damm v-belts are one of a couple reasons I converted to a serpentine setup. I HATE v-belts.
85 Wagoneer 5.2/44RE/NP229
98 TJ 5.9/46RE/D300
01 F250 Powerstroke
***Space saved for a J-truck***
Old 05-08-2013, 10:13 PM
Mine came stock with serpentine belt in '84
UPDATE: Fix one thing, another breaks... STORY TIME! Gas Pumper General FSJ Tech 21 03-13-2010 08:56 AM
time to admit defeat... Brad W. Off-Road FSJ Tech 18 03-08-2007 02:12 PM
Cs-144 install (with pics!!!) Wagoneerlover Electrical 19 03-06-2007 05:16 PM
ok, what did i break??? (kinda long) Madduck General FSJ Tech 3 10-15-2006 09:55 PM
QuadraTrac - Full Time or Part Time uglyjeepling General FSJ Tech 11 08-09-2004 04:22 PM
