05-03-2013, 08:38 PM
What's involved in NP229 --> NP242 swap?
My 229 transfer case just imploded, right after I passed smog (the Jeep gods know I got a bit of tax money back this year). As I drove home in 2wd, it sounded like my kids eating hard candy near a PA system. Quite ugly.
I've got a line on a local NP242 with SYE from a Grand Cherokee. I've confirmed its a 23 spline, so I think it should bolt up to my TF727 okay.
But I'm not sure what I need to do beyond that.
I've read nearly every forum thread on NP242s, but I'm feeling in the dark still, so i felt I needed to post a thread. I know the rear drive shaft will need an adapter, at minimum, to bolt to the SYE, but will I have to buy an all new shaft? Is there an adapter that will allow my stock rear shaft to bolt up? Is there an XJ or ZJ shaft that I could use instead? (I'm assuming not because of the slip yoke feature, but I'd love to be corrected.)
What will I have to do differently to the front shaft?
A reman 229 is out of my budget range (upwards of $800 with tax), whereas the 242 with SYE is local and only $250.
Any insight/advice/experience you can provide would be great.
Tucker
88 GW, AMC 360 with Doug Thorley headers, Howell TBI, NP242, TF727, 3.31 gears and the tow package, Magnaflow muffler and cat, BJ's 4" springs + 2" blocks and 1" shackles, and 1" body lift, 32" BFG's, aluminum rad, K20 front brake calipers.
____________________
My Jeep has tricked me into thinking I know what I'm doing.
05-03-2013, 09:17 PM
Big Meanie
The 242 will probably have a different clocking to it so it will most likely hang lower.
Depends on the style SYE as to what type of shaft end you need to bolt it up.
Your shaft might be fine. The 242 is smaller than the 229 and shorter if I remember correctly so at most you'd need to have a new shaft made up or find a longer one and have it cut down. The front shaft should be fine unless it's out of a newer GC with the double CV front shaft. Then you will need to find an older style front output yoke.
You will need to do some shifter linkage mods to get it to shift with your current flag shifter.
You might be better off just finding a used 229 or 228 to swap in. They are cheap. I've never gotten more than $50 for the used ones i've sold. And they were all good.
Originally posted by Ristow
i bet it was Simon....
05-03-2013, 09:51 PM
AFAIK the NV242 Jeep front output yoke is the same as the NP229 so front should be fine.
If it has a slip yoke eliminator already you would bolt up the rear driveshaft the same way only issue would be length.
I have a longer rear shaft from a QT rig so if you do it and need a longer one...hit me up I'm fairly close probably ~70 miles.
http://www.ifsja.org/forums/vb/showthread.php?t=163306
05-03-2013, 10:29 PM
Thanks, guys. I'm going to pull the trigger I think and get the 242. I'm under a little time crunch, and 229s are nowhere to be seen around here. Besides, the 242 is a bit more popular and easy to manage repairs/upgrades/etc. And no VC to worry about.
I'll have to figure out the speedo cable adaptation, as well, but I don't worry how fast I'm going. I'm usually more concerned with how slow.
Tony, I will definitely keep that offer in mind as I do the R&R. I appreciate it.
Tucker
05-04-2013, 06:03 PM
Bought it. Now I've got to install it.
As a nerdist academic, I'm going to think it through, buy what I need, take some pics, and perhaps post an overly verbose write up.
Tucker
05-04-2013, 06:25 PM
Did you see the post for a NP129 for $75?
05-04-2013, 06:45 PM
The input shaft of the NP242 is shorter than the NP229. Make sure there is enough shaft engagement on the seal. If not, there are seals you can get that have a "snout" on them that will reach 3/8 or so further back to reach the shorter input.
85 Wagoneer 5.2/44RE/NP229
98 TJ 5.9/46RE/D300
01 F250 Powerstroke
***Space saved for a J-truck***
05-04-2013, 08:58 PM
I Can't Wait To See This Write-Up!
1980 Jeep J-20
1979 Jeep J-10 Honcho
1991 Jeep Grand Wagoneer
Unknown
1968 Plymouth Satellite
1978 Camaro- back in action
05-05-2013, 06:55 PM
Pulled the 229 this afternoon. Measured the depth of the input shafts of both. The 229 is three inches deep; the 242 is two and a half inches. I'm hoping that half inch won't be a real issue.
I don't think it will affect the mounting of the 242 since both transfer cases have the same measurement from the mounting flange of the case itself to the end of the input shaft (2 1/4"). If the tranny doesn't go all the way into the 229's input shaft, then I think it will be fine. I'll climb under there more tomorrow to see if there's going to be an issue here.
Tucker
05-06-2013, 10:44 PM
It's actually 15/16" difference, ergo the 1" spacer is needed going the other way.
05-06-2013, 11:28 PM
Just lube the seal real good with Lubriplate (or something similar) and install, you'll see where the seal rides.
98 TJ 5.9/46RE/D300
01 F250 Powerstroke
05-06-2013, 11:37 PM
I'm not following this. Can you explain this more?
Tucker
05-06-2013, 11:53 PM
Here are pics of the 2 1/4" measurement I'm talking about.
They aren't the best pics, but the top one is the 242 and the bottom one the 229. Where does the 15/16" spacer you are talking about come into play?
Tucker
05-07-2013, 12:18 AM
If you put an AW4 in an FSJ and use the FSJ tcase, you need a 1" spacer. Going the other way you will have a matching gap between the trans output shaft and tcase input shaft bottom. (opposite of the way you are going) That means you will have 15/16" less engagement of the tcase input.
05-12-2013, 11:30 AM
Actually, that's not the case. I was worried about the same thing, so I measured when I pulled the 229. The output shaft for the TF727 is about 2" total (it doesn't even reach the edge of the transmission/transfer case mating surface), so it never even got close to bottoming out on the 229 input shaft. If anything, there will be less dead space inside the 242 input shaft than there is inside the 229. My guess is that they made the 229 input shaft long enough to accommodate a manual tranny output shaft, which is usually considerably longer than an auto output shaft.
Tucker
05-30-2013, 04:25 PM
All done!
Running and working with the new-to-me NP242 and the Novak shifter.
I'll do a write up if there's any interest, but if not, I'm still a happy guy.
Tucker
05-30-2013, 05:02 PM
Nice! What did you end up doing?
98 TJ 5.9/46RE/D300
01 F250 Powerstroke
05-30-2013, 05:15 PM
Do the write up please. Did you have to get a new rear drive shaft.
05-30-2013, 05:48 PM
I'm interested in a write up as well
Dan
81 Cherokee Laredo- 360 727 NP219 SOA/SF 35 Coopers 4.56 Gears
83 Cherokee - Katy- long term project
89 Grand Wagoneer- 360 727 NP229 31x10.50's on slot rims
05-30-2013, 06:49 PM
1st Chair, Cowbell
+1. And please be overly verbose. I hope you took pictures. I like to look at pictures.
Thread Tools |
Display Modes |
