Old 03-19-2013, 02:05 PM
the original Honcho's Avatar
tailgate window switch
My Switch On The Dash Quit Working. The Key In The Back Still Rolls It Up And Down.
Could It Be A Blown Fuse? Bad Switch? Wiring? I Am Almost As Apprehensive With Electrical As I Am With Carburetors, lol.
1980 Jeep J-20
1979 Jeep J-10 Honcho
1991 Jeep Grand Wagoneer
Unknown
1968 Plymouth Satellite
1978 Camaro- back in action
Old 03-19-2013, 02:08 PM
BillyWagoneer's Avatar
BillyWagoneer BillyWagoneer is offline
most likely the switch. that happend to me.
87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
True Dual side pipes
TF 727 & np229
B&M Shift Kit
12 Bolt rear & D44 front
4.10's and ARB lockers
SOA & shackle flip
33 12x5's
Empty wallet
Old 03-19-2013, 02:14 PM
Did You Buy A New Switch Or Find A Used?
1980 Jeep J-20
Unknown
Old 03-19-2013, 03:58 PM
i think there discontinued everywhere, i grabbed one from the junk yard. may wanna try takin your switch off and cleaning the contacts. generally thats the first thing.
87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
TF 727 & np229
B&M Shift Kit
SOA & shackle flip
33 12x5's
Empty wallet
Old 03-19-2013, 04:14 PM
TGW And BJs? I Was Hoping TheyWould Have New
1980 Jeep J-20
Unknown
Old 03-19-2013, 04:19 PM
86GWABQ's Avatar
86GWABQ 86GWABQ is offline
Very difficult to find new. I looked everywhere for new with no luck... Found a used one through www.montanaoverland.com.
Old 03-19-2013, 07:32 PM
mdcptman's Avatar
mdcptman mdcptman is offline
Jeep Therapist
Its easy to take apart and put back together. Clean the contacts, a little dielecric grease, and it might work. Be careful to do it on a smooth clean surface, and pay attention to how it comes apart. There are tiny springs...it helps if ur work surface is white....good luck!
88 Grand Wagoneer
360/727/NP208/dana 3.31s
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Quote From Friend's Mom:
Old 03-19-2013, 08:04 PM
DoesAnyone Know TheSwitch Is Dpdt Or Dpst?
1980 Jeep J-20
Unknown
Old 03-20-2013, 04:41 AM
mdcptman's Avatar
Jeep Therapist
Duh.....what?
88 Grand Wagoneer
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Old 03-20-2013, 05:25 AM
men in black's Avatar
There are two power sources for the tailgate rear window. If the tailgate switch is not centered the dash switch will not work.
The plastic paddle of the tailgate switch maybe broken. You can use a rear passenger window switch to fix it.
Its not the best fix but will work.
If your driver power seat and mirrors still work the 30 amp fuse for the tailgate window is still good.
Old 03-20-2013, 07:05 AM
serehill serehill is offline
Gone,Never Forgotten.
wow my post got deleted. Whys that???????????
The switch functions as a double pole double throw but it actually is a DTDT with connecticity between post in the center position. It is a unique switch. It's not a standard switch. I guess I shouldn't have posted my solution. It was part of the answer. I guess you have to find it yourself??
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 03-20-2013, 07:07 AM
Strode's Avatar
Strode Strode is offline
1st Chair, Cowbell
Originally Posted by serehill
The switch functions as a double pole double throw but id actually a dt with connecticity between post in the center position. It is a unique switch. It's not a standard switch. I guess I shouldn't have posted my solution.
It's not you. There were a bunch of posts from last night that disappeared.
Ristow's Bunker
Old 03-20-2013, 10:53 AM
svining's Avatar
svining svining is offline
Wink I'm lazy.......
These are on Ebay all the time for very reasonable prices, I've got two spares for each switch
Flashlight
"I started with nothing, I still got most of it left"
1982 GW,Stock, No Emissions Equip.
Mallory HEI, AMC 360, Motorcraft 2150
Old 03-20-2013, 11:50 AM
yeah
The best thing to do is uprade the system to a completely better system & do away with the unique switch.
these switches at best are all over 20 years old & the entire system uh has a vacuum to it.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 03-21-2013, 12:15 PM
So After A Quick Trip To The Junkyard For A Simple Side Marker Light, The KeySwitch For The Back Window Will Not Roll The Window Up.
it's Done This Before But It Would Work After Jiggling The Key. After About 20 Minutes ItStill Would.Do Nothing. Where Do I Start?
1980 Jeep J-20
Unknown
Old 03-21-2013, 12:18 PM
safety switch on ds of tailgate.
push in on the gate and try again
Old 03-21-2013, 12:47 PM
yeppers
Left side is where the switch is slim chance
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 03-21-2013, 02:19 PM
does anybody have any suggestions as to how to get the window up?...I live in a pretty bad neighborhood...
1980 Jeep J-20
Unknown
Old 03-21-2013, 03:52 PM
the hard way??
Hook a battery up to the motor wires by removing the inspection plate & pulling the wires off the switch put them on the battey one way it goes down the other it goes up.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 03-21-2013, 04:00 PM
Provided the wiring to the motor is still intact?
And the safety switch is closed? (you checked it like suggested above?)
...you can unplug the harness coming out of the tailgate under the truck and apply power to the tailgate motor wiring and raise/lower the window depending on polarity.
Done it several times in the boneyard to grab parts vs. the hard way.
'88 GW Dash Tailgate Window Switch 88geedub General FSJ Tech 2 01-24-2011 11:35 PM
Funny Tailgate Window Story tmlint General FSJ Discussion 4 01-17-2011 02:22 PM
front window switch for the tailgate superc_1 General FSJ Discussion 7 01-27-2009 01:37 PM
rear window switch diagnosis..help. rickauf General FSJ Tech 0 04-16-2007 09:44 AM
