Old 03-21-2013, 04:04 PM
serehill serehill is offline
Gone,Never Forgotten.
NO NO
There's no safety switch if you connect the battery to the motor.
LOL if the safety switch or the tailgate switch is junk feeding from the plug inderneath is useless. If the front switch is bad or there is a power problem then the plug might work.
zero odds zero guess work hook the MOTOR wires up to a battery.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 03-21-2013, 04:06 PM
the original Honcho's Avatar
Originally Posted by serehill
Hook a battery up to the motor wires by removing the inspection plate & pulling the wires off the switch put them on the battey one way it goes down the other it goes up.
I Had It Open But Couldn't Get To Anything Because The Glass Is In The Way. Can I Reach Anything From The Hinge Covers? I Didn't Open Those.
I Backed It Into My Driveway Hoping That Will Deter Thieves While I Pick Up My Daughter From School.
1980 Jeep J-20
1979 Jeep J-10 Honcho
1991 Jeep Grand Wagoneer
Unknown
1968 Plymouth Satellite
1978 Camaro- back in action
Old 03-21-2013, 04:09 PM
I never said there was...
I'm talking about raising the window w/o removing the tailgate inspection cover and unplugging wires.
Originally Posted by babywag
Provided the wiring to the motor is still intact?
And the safety switch is closed? (you checked it like suggested above?)
...you can unplug the harness coming out of the tailgate under the truck and apply power to the tailgate motor wiring and raise/lower the window depending on polarity.
Done it several times in the boneyard to grab parts vs. the hard way.
I Have Been Checking The Switch Every Time I Tried It. Do You Happen To Know What Color The Wire Is?
1980 Jeep J-20
Unknown
Old 03-21-2013, 04:12 PM
The safety switch wires are tan, and can easily be bypassed by jumpering them together.
Old 03-21-2013, 04:52 PM
yeah it's difficult
You can try it from the plug underneath but as I stated if there is a problem with the safety switch or the tailgate switch it still won't work. Nobody said anyone said they were or weren't.
I'm not saying the plug won't work I'm saying if it is one of the tailgate switches it won't. I've been there. If the tailgate switch fails there's only one way to get to it. well you could smash the glass.
Also you can remove the clips off the glass & push it up wedge it in or hook some wires up to the motor re-connect the window then roll it up.
To the point if the motor isn't intact then all this is a Moot.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 03-21-2013, 06:54 PM
Is There 2 Magic Wires I Can Get To From AnyWhere That I Can Jump And MakeThis Thing Go Up?
EDIT: http://oljeep.com/gw/elec/90_numeric...8W_Page-41.jpg
I Hope This Is My Answer!
1980 Jeep J-20
Unknown
Old 03-21-2013, 07:46 PM
If there's is it's the ones I pointed out in like #3
Bottom left corner of the diagram the safety switch but as stated a million times if the safety switch is bad that is the magic bullet. Notice the 2 wires going to the switch one goes via the switch to the motor. Jump those 2 if you lucky only from inside the tailgate. BTW Mine were white. ONLY if the safety switch is bad other than that the Motor wires & connecting a battery to them. there's not a lot of options & whoever designed the system had no thought of a user servicable system. I know there's no good news but I've messed with these things a lot that is why I redesigned mine.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 03-22-2013, 12:24 AM
cma's Avatar
cma cma is offline
check out http://www.ebay.com/sch/i.html?_from=R40&_sacat=0&rt=nc&_nkw=tailgate+swit ch
Markus!
Picture story:
Old 03-22-2013, 08:42 AM
men in black's Avatar
Yes, If your tailgate key switch is centered and your safety switch is made or jumpered.
In the center of page 41 there are two plugs, one (left rear engine compartment at dash,
The other under center of rear body) Unplug before applying 12 volts.
You can use these to made the window go up or down. just contact 12 volt to these wires.
Old 03-22-2013, 12:33 PM
Yes, there are only 2 wires you need to locate/jumper.
A brown wire and a tan wire.
IIRC brown gets (-) tan gets (+) to lower the window reverse the polarity to raise the window.
You can jumper it @ the connector @ the firewall, or under @/~ the rear crossmember.
I bring a 14v drill battery w/ jumpers to the yard when I go for exactly this purpose.
I also bring a small chunk of thick wire to manipulate the safety switch if needed.
The safety switch is almost never bad, same as the window motor.
It's usually the wire connection(s), or the arm needs a little adjustment from 20+ years of use.
While the system isn't ideal, if the wiring/connections are in good shape/clean and tight it works just fine.
Old 04-10-2013, 04:36 PM
Well, Here Was My Problem
Fixed It With A Switch From A 1990 FordCrownVic Switch In The Tailgate!!
1980 Jeep J-20
Unknown
'88 GW Dash Tailgate Window Switch 88geedub General FSJ Tech 2 01-24-2011 11:35 PM
Funny Tailgate Window Story tmlint General FSJ Discussion 4 01-17-2011 02:22 PM
front window switch for the tailgate superc_1 General FSJ Discussion 7 01-27-2009 01:37 PM
rear window switch diagnosis..help. rickauf General FSJ Tech 0 04-16-2007 09:44 AM
