Old 04-19-2002, 12:46 PM
Dash Driver Dash Driver is offline
Question
I have a 78 wag and it has the q-track all wheel drive. It looks like I need to get the rotors turned because the brakes are pulsating as I stop. I am trying to remove them to take them to the shop and having some problems. Looking at the Exploded view in chiltons, I am at the OUTER LOCKNUT,LOCK WASHER and INNER LOCKNUT. Do I need a special tool to remove this? Should it pull stright out or twist?
Old 04-19-2002, 01:14 PM
64Trvlr 64Trvlr is offline
Traveler
First you need to remove the caliper. Then you use a special socket to remove the outer locknut then pull the washer out, next use the socket again to remove the inner locknut. Pull the rotor off the spindle and turn it over, remove the seal in the middle of the rotor, take the bearings out and clean and inspect them.
41 MB<br />46 CJ-2A 307,T90,D18,27,44,4:27\'S<br />64 Traveler, 350,sm465,np205,44\'s w/4:88\'s, spool, 34X9.50 TSL\'s,3\" factory lift, Line-x interior, PS, Dual Optima\'s, custom overhead console,Warn XD900i,custom bumpers<br /><a href=\"http://images.andale.com/f2/116/106/4651773/1009696569938_64trvlrconsolegrp.JPG\" target=\"_blank\">Overhead C
STOLEN! Dana 300 Twin Stick
Old 04-19-2002, 03:03 PM
GM style 4x4 hub wrench is needed... about $20 for a good one with the '4 teeth' INSIDE the top of the hub wrench.
with this you remove the outer locking nut.. then finagle the lock washer off the bearing retaining nut... it's keyed with little holes to line up with the hole on the bearing retaining nut... so don't mix up the lock nut with the retaining nut...
Todd
www.ttsfabworks.com
Old 04-19-2002, 03:55 PM
arter's Avatar
arter arter is offline
I found that a snap ring pliers with straight pins was helpful for pulling and installing the washer. My retainer has a pin that the nearest hole in the washer has to go over. Had to adjust the retainer for the washer to line up with the pin and keyway. My rotors were shot, new ones from the 'zone for $20 each.
M715NT; TBI 401, 400, 1339, 44's, 4.10's, ARB's, 35's, wag frame
Old 04-21-2002, 10:18 AM
JEEPGUZZZI JEEPGUZZZI is offline
New rotors for 20 bucks??? I knew that I could get new brake calipers (including all hardware ) for less than $15. I had no idea that I could get those great big rotors for 20 bucks!
Old 04-21-2002, 10:24 AM
WINGO WINGO is offline
Thumbs up
At the Autozone you can get rebuilt calipers for $ 13.99 plus $ 10.00 core.
<b>WINGO</b><br />Vineland, NJ<br />USA<br /> 1984 GW 360 <br />Front Axle: \'79 W/T, SOA<br />Rear Axle: \'80 W/T, Riverbeast Kit<br />Body: 3 \" Body Lift<br />Transfer case: \'82 CJ, Twin Stick Dana 300<br />Wheels: Stock Rims w/ 31\" X 10.5\" Kelly MT<p>A good reason to buy Todd\'s kit!<br />http://imaget.webphotos.iwon.com/100...PM0.601864.jpg
