Old 04-25-2002, 09:50 PM
bob13's Avatar
bob13 bob13 is offline
Question
Not sure whats in the Trans. now and I need to change the filter.
I'v did a search and found that there are two sides to what to put in it, dexron III and ATF+3.
The ATF+3 is for Chrysler Transmissons, but I don't know if thats what it has in it.
So should I change the filter and put in ATF+3 or Dexron III?
Not sure if i should mix the two?
Thanks
bob
89Wagoneer SOLD to Millerluck
Old 04-25-2002, 11:17 PM
T-Bone T-Bone is offline
My owners manual say to use Dextron II, which I couldn't find of course, so I use Dextron III. Works pretty good for me.
But it would really depend on what the PO put in.
\'88 GRAND WAGONEER (STOCK)<br />\"MYSTERY MACHINE\"<br />\"IT\'S A MYSTERY WHETHER THIS MACHINE WILL START\"
Old 04-25-2002, 11:31 PM
SpruceMoose SpruceMoose is offline
and unless you drain the torque converter, you will never get all the old fluid out anyway. i used amzoil synthetic, which will mix with all atf types. and i wanted to switch to synthetic anyway.
sm.
88 Grand Wagoneer<br />\"Spruce Moose\"<br /><br />See the Moose at:<br /><a href=\"http://www.fsjworld.com/mygallery.asp?id=3294\" target=\"_blank\">http://www.fsjworld.com/mygallery.asp?id=3294</a> <br /><br />AMC 360, DANA 44 F/R 2.72, TF 727, NP 229<br />Jacobs Pro-Street Ignition, Edelbrock 4bbl Intake with Holley 2bbl Analog Pro-Jection<br />Flowmaster 2.5\" 50 Series Delta muffler and tubing<br />K&N cone air filter, Amzoil fluids all around<br />31x10.5 BFG A/T KO<br />Rusty\'s 4\" lift<br />Home-made tube nerfs and bumpers<br />BJs Muscle grill<br />HF,VHF,UHF ham rigs and too many antennas (not)<br />8-Ball shift knob from college (1975)<br />Hella fog and driving lights<br />Kenwood MP3 HU, Orion sub amp, Jensens all around<br /><br />Mileage? We don\'t need no stinkin\' mileage!
Old 04-25-2002, 11:58 PM
Use Dexron III. It's just a new/later/improved version of Dexron II which isn't made anymore. ATF3 is only for the later (94ish and up) Chrysler trannies(says so on the bottle).
Old 04-26-2002, 01:10 AM
Rogue's Avatar
Rogue Rogue is offline
360 AMC
i worked for a transmission shop for a while - we used the same fluid in all trans
Old 04-26-2002, 06:23 AM
WINGO WINGO is offline
Thumbs up
You can also flush your transmission by disconnecting the return line from your transmission cooler and adding fluid on an itermittent basis until clean. Be sure to shift the transmission in all gears a few times while doing this.
<b>WINGO</b><br />Vineland, NJ<br />USA<br /> 1984 GW 360 <br />Front Axle: \'79 W/T, SOA<br />Rear Axle: \'80 W/T, Riverbeast Kit<br />Body: 3 \" Body Lift<br />Transfer case: \'82 CJ, Twin Stick Dana 300<br />Wheels: Stock Rims w/ 31\" X 10.5\" Kelly MT<p>A good reason to buy Todd\'s kit!<br />http://imaget.webphotos.iwon.com/100...PM0.601864.jpg
Old 04-26-2002, 10:35 AM
bob13's Avatar
Thanks for the help.
I did'nt know that about ATF+3 Joe. I thought it was for all Chryslers.
Well I better ge out there and do it, I hope its got Dexron in it.
Thnks
bob
