Old 04-06-2020, 04:02 PM
King Zarkon King Zarkon is offline
Oil Light
OK! One fire today, and fixing one issue always (for me anyway) seems to lead to the discovery of another.
On my 3 hour trek yesterday, I noticed the oil light flickering a little bit for about the first 10 minutes of so of driving, and then it went away.
As I was installing my new battery today, I noticed that the connector for the oil light was loose. I reseated it, and now I have the oil light persistently on.
Hoping some of you could possibly advise possible next steps. I was thinking an idea might be to order an actual gauge to get a reading. I'll be changing the oil and filter tomorrow, but the level is good presently.
Thanks again in advance!
KZ
Old 04-06-2020, 07:17 PM
Crankyolman's Avatar
My first step before doing anything else, including driving it, would be to find out if I had oil pressure. Put a mechanical gauge on it and see what that indicates.
'72 J4500
Old 04-07-2020, 03:23 PM
OK - I will do just that.
Another question, I have a '64 but with a later AMC 360. My water temp rises upon starting to about a third, then drops down to zero. It does this every time. Do I need a new sending unit?
Old 04-10-2020, 01:48 AM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
Oil lights that intermittently flicker are caused by defective pressure switches more often than not.
Old 04-10-2020, 08:31 PM
67GMC's Avatar
67GMC 67GMC is offline
There's also that Constant voltage regulator (CVR) that's part of the coolant temp gauge. I think the oil pressure gauge gets power through that as well. Could be related?
My Stable:
1984 Jeep Grand Wagoneer, 5.9L, 4x4, Auto (newest project)
1997 Volkswagen Cabrio, 2.0L, Manual
2005 Kia Sportage, 2.7L, Auto
2006 Toyota Sienna, 3.3L, Auto
2018 Toyota RAV4, 2.5L, Auto
Recent projects (no longer with us)
1987 Jeep Cherokee Laredo, 4.0L, 4X4, Auto
1967 GMC 910, 283V8, 4SPD (RIP)
Old 04-11-2020, 01:44 AM
FSJunkie's Avatar
No. The voltage regulator supplies power to the fuel gauge and temperature gauge only. Any problem with the regulator causes equal fluctuation of both gauges together. The oil light and amp light are completely separate circuits.
What happened with your oil light is the switch has shorted internally, grounding it's terminal. Grounding that terminal makes the light come on. The light only flickered before because the connection to the terminal was loose and dirty. Now it's clean and making good contact, so the light is on fully. The switch is very easy to test for continuity or open. My bet is replacing it will let the light function properly.
The fuel gauge is weirder, especially if it's reading is varying separate of the fuel gauge, eliminating the voltage regulator as the cause.
Old 04-11-2020, 08:32 PM
67GMC's Avatar
I was thinking about his issue with the coolant temp moving around that it could be related to the CVR. You're correct about the oil pressure. I forgot it was the fuel gauge and temp gauge on the same circuit.
Oil pressure sender / switches are dirt cheap so changing it is easy and then if you have a manual gauge, you can install that too and see what it reads.
My Stable:
Old 04-12-2020, 09:11 AM
------> One thing to remember for this Jeep <------
It is basically an 80s GW frame and running gear under a 64 body. When it comes to the idiot lights and gauges, the correct sender(s) may or may not be installed for the 64 instrument cluster.
Old 04-13-2020, 01:40 AM
wincher's Avatar
wincher wincher is offline
Which car do you have with the oil light?
the instrumention of my Chief has no light for oil pressure, only a oil pressure gauge.
Warning lights (idiot bulbs) for park brake, fasten belts and E-Drive only.
It
79 chief 360amc
02 wj 4.7HO Overland
Old 04-15-2020, 09:07 AM
It
That is correct. No oil pressure light when there is a gauge. Year/model/equipment is important info, and the OP should have included it at the start or in his signature file. A '64 with a 360 conversion could be anything custom, or have no gauge?
Old 04-24-2020, 11:10 AM
Hey Guys,
Thought my signature had my rig details - I'll update that right away.
Finally got my mechanical gauge installed yesterday. Reads 60 at idle on startup, between 15-60 while driving, and once warm idles around 20. That seems pretty good to me but I'm open to any thoughts.
Regarding voltage regulator, and lack of matching running gear to gauge, possible this is the problem with my temp gauge climbing then dropping to zero? I think I'll go the mechanical route as well. Installed the oil gauge in the opening for the ashtray and makes for a nice fit with a bit of filing down!
How to: Fixing final edition flip-lid light up visors adzam General FSJ Tech 3 11-25-2012 10:29 AM
third brake light? Eric S. General FSJ Discussion 9 12-23-2011 04:16 PM
Charge light wire connection ? 1cdccop General FSJ Tech 0 12-26-2010 06:44 PM
Rhino grille fog light install w/pics Maryland Rick General FSJ Tech 27 10-14-2007 08:43 PM
Courtesy light and dome light TestTeam General FSJ Tech 10 06-01-2007 11:20 PM
