Old 08-06-2013, 12:04 PM
jcountryman's Avatar
jcountryman jcountryman is offline
A/C Compressor valve
Just had the AC condenser replaced, next is the valve on the compressor... problem is, the one from Napa (that is supposed to be the stock one) has the wrong size flare fitting that runs to the hose--it's too small.
All I can think of is that the compressor is an aftermarket, but the labels are missing.
Anyone else have this problem? Solution? I could have a custom hose made, but that can get pricey. Would rather replace the valve if possible.
My rig is a '90.
TIA
Julia
Julia Countryman
1990 Jeep Grand Wagoneer (AKA The Tardis)
A few pics here: http://picasaweb.google.com/10040474...0764102/Waggy#
Building a new one, one part at a time
Old 08-06-2013, 03:08 PM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
They should have an assortment of different service valves in the TEMP book. Some NAPAs have bins of assorted adapter fittings in steel and brass behind the counter as well, though A/C line flare tends to be different than SAE or JIC flare.
A/C to non A/C (heat only) bowtieman55 General FSJ Tech 16 06-13-2006 09:45 PM
A/C blower is back GED General FSJ Tech 0 07-05-2004 04:16 PM
A/C glitches Ridgbak General FSJ Tech 5 05-23-2003 04:02 PM
A/C retrofit. Puvong General FSJ Tech 2 05-29-2001 01:16 PM
A/C BLUES - PLEASE HELP ! ! Jordo Other 16 08-06-2000 05:32 PM
